JamesDean 10 Posted ... While we all know that the best way to block all traffic if the VPN drops, is to use firewall rules, there is some talk on other forums that is saying that traffic is blocked with other providers that also just use the OpenVPN client, with no firewall rules. Does explicit-exit-notify 5 dictate that if the connection to the VPN is lost, to kill the TAP adapter and route all traffic back through the physical NIC? If we remove that line, would the TAP adapter stay active, even with no connection to a server, and effectively keep traffic from leaking out of the physical NIC? If so, are there any forseeable problems? Quote Share this post Link to post
Staff 10394 Posted ... Hello! The directive has nothing to do with that, please see the OpenVPN manual: --explicit-exit-notify [n]In UDP client mode or point-to-point mode, send server/peer an exit notification if tunnel is restarted or OpenVPN process is exited. In client mode, on exit/restart, this option will tell the server to immediately close its client instance object rather than waiting for a timeout. The n parameter (default=1) controls the maximum number of attempts that the client will try to resend the exit notification message. OpenVPN will not send any exit notifications unless this option is enabled. You can prevent leaks without firewall rules anyway, please see here https://airvpn.org/topic/9797-blocking-non-vpn-traffic-without-firewall-using-routing-router Kind regards Quote Share this post Link to post
mimosa67 1 Posted ... I'm using a router with librecmc, and just switched to AirVPN. The provided AirVPN_foo.ovpn file only works if the explicit-exit-notify line is commented. What might be the cause, and should I be worried about it? Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... Probably something you can't change in the UI. It's a user-defined directive which a small minority of clients don't even know. You can of course just leave it commented, it just means that the server is notified if the client disconnects. If it's not there and you disconnect, after 60 seconds your connection slot is being recycled. It's safer to have it, though. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
mimosa67 1 Posted ... giganerd, thanks - at least now I know what it does, though I'm not sure how seriously to take the vulnerability. Is the threat model a correlation attack? However, I still wonder why my openvpn doesn't like it. I'm not using Eddie or any GUI by the way - just openvpn itself. Quote Share this post Link to post
zhang888 1067 Posted ... The OpenWRT version of OpenVPN on arm/mips doesn't support this directive.See here: https://airvpn.org/topic/16532-solved-with-minor-issue-openvpn-on-openwrt-cc-1505-and-dd-trunk/ There is no risk in commenting this directive, as long as you don't frequently reconnect to VPN serversand need all the 3 slots simultaneously. Not using it does not open a new attack vector, since this hasnothing to do with security at all, it only notifies the server when you decide to gracefully disconnect. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
mimosa67 1 Posted ... zhang888, thank you. Looking at the thread you link to, it sounds as if this may eventually be fixed with an upgrade. It's good to know it doesn't really matter, meanwhile. Quote Share this post Link to post
