From Tauri, DE, it says there aren't any products aviable in my "area" (maybe country; that's logical if the website provides its service only for residents in the Nederlands.. strange thing is that they have a german language aviable)
But website is accessible.
Of course the website is accessible.
But it appears to know that you're accessing through a VPN and alters the functionality so that the free streaming is not available even when connecting through a server in the Netherlands.
Yeah, my friend also tried with his provider and it no longer works. I searched and it appears no one is able to get it for free anymore using tunnels. They're saying it still works from NZ but I have not confirmed that. Besides, if it does they'll shut it down soon as well. In August a support person from the site told me it was currently free in the NL but this could change. Perhaps it changed and it's not a blacklisting thing? I knew it was too good to last.
I haven't tried this but it's fairly current:
http://www.reddit.com/r/Seahawks/comments/1qt0d9/use_nfl_game_pass_without_vpn_if_someone_shares/
Perhaps this might work if it still is free to residents in the NL (& their is enough throughput):
https://airvpn.org/topic/10302-michigan-ip-adress/?p=13593
I'd imagine they wouldn't appreciate it. Perhaps you could donate some of your bandwidth and setup a relay to (sort of) compensate? If you're gonna try it, it'll probably be better to reduce your circuit to 1 relay.
I tried using Tor Exit Nodes in the NL but it didn't work. I also tried through NZ (and CH) but got the same, there aren't any products available in my "area" message.
I was able to get it to work using a proxy:
http://www.hotukdeals.com/freebies/watch-free-nfl-season-1644089#comments
However, I didn't try the NL, I tried it with the AR proxy.
This was a recomended site to find proxies:
http://www.proxy-listen.de/Proxy/Proxyliste.html
The FoxyProxy Add-on is integrated in this site. You can, "Configure FoxyProxy in a single click".
Once you establish a connection, you can disable the proxy and use your (Internet) bandwidth.
However, if the stream is dropped it won't re-negotiate.
