matango
Where do I activate Socks in AIRVPN client?
You need to right-click the Air client tray icon and select "Preferences". You'll see a "Proxy" section where you define the type of proxy (http or socks), proxy IP and port.
Thanks.
I set Socks, but having a few issues connecting after setting up TOR. I'm picking TCP for that. Just won't connect over TOR today.
You need to right-click the Air client tray icon and select "Preferences". You'll see a "Proxy" section where you define the type of proxy (http or proxy), proxy IP and port.
Guest summoner23
Do you guys offer socks proxies?
Thanks.
Are you using XP? If so, as soon as the default gateway gets overridden by the VPN connection, the tor.exe program that provides the SOCKS interface for the VPN client loses connectivity to the VPN server. See:
https://airvpn.org/topic/10172-connection-disconnection-loop/page-2?do=findComment&comment=13392
No, I'm having this issue with Vista.
Thanks.
