dwright 25 Posted ... Hi, I can connect to Air over my university's wifi with my iPod Touch, but my laptop running Windows 7 won't do it. I have tried using an SSH connection to see if that would circumvent any deliberate blocking, but that didn't work either. The wifi in general behaves strangely with my laptop - it does not give me internet access until I troubleshoot it, when Windows asks to reconfigure DHCP settings. I don't know what that means, but could it be deliberately configuring Windows not to allow VPN connections, but this blocking fails with iOS? If anyone knows a fix, please let me know. Quote Share this post Link to post
Laiquendi 1 Posted ... Not sure if it's the case, but I had similiar problem and using the "Resolved hosts in .ovpn file" from "Advanced options" in "Config. Generator" solved my problem with connecting at Uni. Quote Share this post Link to post
dwright 25 Posted ... I noticed there was no response from the staff yet, so I'm copying in a log of it failing to connect: Wed Oct 30 12:14:28 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013Enter Management Password:Wed Oct 30 12:14:28 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25365Wed Oct 30 12:14:28 2013 Need hold release from management interface, waiting...Wed Oct 30 12:14:28 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25365Wed Oct 30 12:14:28 2013 MANAGEMENT: CMD 'state on'Wed Oct 30 12:14:28 2013 MANAGEMENT: CMD 'log all on'Wed Oct 30 12:14:28 2013 MANAGEMENT: CMD 'hold off'Wed Oct 30 12:14:28 2013 MANAGEMENT: CMD 'hold release'Wed Oct 30 12:14:29 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]Wed Oct 30 12:14:29 2013 UDPv4 link local: [undef]Wed Oct 30 12:14:29 2013 UDPv4 link remote: [AF_INET]84.39.117.56:443Wed Oct 30 12:14:29 2013 MANAGEMENT: >STATE:1383135269,WAIT,,,Wed Oct 30 12:15:29 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Wed Oct 30 12:15:29 2013 TLS Error: TLS handshake failedWed Oct 30 12:15:29 2013 SIGUSR1[soft,tls-error] received, process restartingWed Oct 30 12:15:29 2013 MANAGEMENT: >STATE:1383135329,RECONNECTING,tls-error,,Wed Oct 30 12:15:29 2013 Restart pause, 2 second(s)Wed Oct 30 12:15:31 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]Wed Oct 30 12:15:31 2013 UDPv4 link local: [undef]Wed Oct 30 12:15:31 2013 UDPv4 link remote: [AF_INET]94.229.74.90:443Wed Oct 30 12:15:31 2013 MANAGEMENT: >STATE:1383135331,WAIT,,, Thanks for the response Laiquendi, but I already use resolved hosts. Quote Share this post Link to post
Staff 10452 Posted ... Hello! Please try to connect to different servers and ports. In particular, test port 53 UDP and 80 TCP. Kind regards Quote Share this post Link to post
dwright 25 Posted ... Okay, I tried the proposed ports and 2018 alternate entry as well, but no luck. Here is another log of it failing: Mon Nov 11 11:58:26 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013Enter Management Password:Mon Nov 11 11:58:26 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25365Mon Nov 11 11:58:26 2013 Need hold release from management interface, waiting...Mon Nov 11 11:58:26 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25365Mon Nov 11 11:58:26 2013 MANAGEMENT: CMD 'state on'Mon Nov 11 11:58:26 2013 MANAGEMENT: CMD 'log all on'Mon Nov 11 11:58:26 2013 MANAGEMENT: CMD 'hold off'Mon Nov 11 11:58:26 2013 MANAGEMENT: CMD 'hold release'Mon Nov 11 11:58:27 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]Mon Nov 11 11:58:27 2013 UDPv4 link local: [undef]Mon Nov 11 11:58:27 2013 UDPv4 link remote: [AF_INET]78.129.153.59:2018Mon Nov 11 11:58:27 2013 MANAGEMENT: >STATE:1384171107,WAIT,,,Mon Nov 11 11:59:27 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Mon Nov 11 11:59:27 2013 TLS Error: TLS handshake failedMon Nov 11 11:59:27 2013 SIGUSR1[soft,tls-error] received, process restartingMon Nov 11 11:59:27 2013 MANAGEMENT: >STATE:1384171167,RECONNECTING,tls-error,,Mon Nov 11 11:59:27 2013 Restart pause, 2 second(s)Mon Nov 11 11:59:29 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]Mon Nov 11 11:59:29 2013 UDPv4 link local: [undef]Mon Nov 11 11:59:29 2013 UDPv4 link remote: [AF_INET]84.39.116.181:2018Mon Nov 11 11:59:29 2013 MANAGEMENT: >STATE:1384171169,WAIT,,,Mon Nov 11 11:59:41 2013 SIGTERM received, sending exit notification to peerMon Nov 11 11:59:46 2013 SIGTERM[soft,exit-with-notification] received, process exitingMon Nov 11 11:59:46 2013 MANAGEMENT: >STATE:1384171186,EXITING,exit-with-notification,, Any other solutions? Quote Share this post Link to post
Staff 10452 Posted ... Hello! Something is blocking OpenVPN: Mon Nov 11 11:59:27 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Since you can connect with your iPod, it should not be a block from your university. For testing purposes, can you momentarily disable your firewall and try again? Kind regards Quote Share this post Link to post
dwright 25 Posted ... Hi, I use Malwarebytes Pro and Windows Firewall. Disabled Windows Firewall and "website blocking" in Malwarebytes and it still didn't work. Note: when I connect to the wifi, it requires administrator priviliges to enable DHCP. Could this be changing some setting that blocks it? Quote Share this post Link to post
dwright 25 Posted ... Sorry to be a pest, but I thought I'd post the log of it failing with Windows firewall and all Malwarebytes active protections (filesystem protection and wesite blocking) disabled. Any more suggestions? Tue Nov 19 14:31:51 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013Enter Management Password:Tue Nov 19 14:31:51 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25367Tue Nov 19 14:31:51 2013 Need hold release from management interface, waiting...Tue Nov 19 14:31:52 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25367Tue Nov 19 14:31:52 2013 MANAGEMENT: CMD 'state on'Tue Nov 19 14:31:52 2013 MANAGEMENT: CMD 'log all on'Tue Nov 19 14:31:52 2013 MANAGEMENT: CMD 'hold off'Tue Nov 19 14:31:52 2013 MANAGEMENT: CMD 'hold release'Tue Nov 19 14:31:52 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]Tue Nov 19 14:31:52 2013 UDPv4 link local: [undef]Tue Nov 19 14:31:52 2013 UDPv4 link remote: [AF_INET]84.39.116.179:53Tue Nov 19 14:31:52 2013 MANAGEMENT: >STATE:1384871512,WAIT,,,Tue Nov 19 14:32:52 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)Tue Nov 19 14:32:52 2013 TLS Error: TLS handshake failedTue Nov 19 14:32:52 2013 SIGUSR1[soft,tls-error] received, process restartingTue Nov 19 14:32:52 2013 MANAGEMENT: >STATE:1384871572,RECONNECTING,tls-error,,Tue Nov 19 14:32:52 2013 Restart pause, 2 second(s)Tue Nov 19 14:32:54 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]Tue Nov 19 14:32:54 2013 UDPv4 link local: [undef]Tue Nov 19 14:32:54 2013 UDPv4 link remote: [AF_INET]94.229.74.90:53Tue Nov 19 14:32:54 2013 MANAGEMENT: >STATE:1384871574,WAIT,,,Tue Nov 19 14:33:01 2013 SIGTERM received, sending exit notification to peerTue Nov 19 14:33:06 2013 SIGTERM[soft,exit-with-notification] received, process exitingTue Nov 19 14:33:06 2013 MANAGEMENT: >STATE:1384871586,EXITING,exit-with-notification,, Quote Share this post Link to post
Staff 10452 Posted ... Hello, the problem: Tue Nov 19 14:31:52 2013 UDPv4 link remote: [AF_INET]84.39.116.179:53Tue Nov 19 14:31:52 2013 MANAGEMENT: >STATE:1384871512,WAIT,,,Tue Nov 19 14:32:52 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) A possible explanation, assuming that nothing in your system is blocking OpenVPN UDP packets, is that your ISP (college) does it, or maybe hijacks packets to 53 UDP to its DNS servers (a shameful practice we detected on Vodafone). However, if the same configuration works with your iPod on the very same network, then it MUST be something in your system. Please try also connections to ports 80 TCP and 443 TCP. Kind regards Quote Share this post Link to post
