stelios
Slow connection to AIRvpn
I am downloading a torrent using Transmission 2.51 on Ubuntu 12.04. Transmission reports I am downloaded from 8 of 36 connected peers. Speed varies from 3 to 40 kB/s. This seems extremely slow. Am I missing something?
This is the bit of /var/log/syslog detailing the connection made by openvpn to AIRvpn (I think). Thanks for any help.
Sep 25 20:26:38 NP-Q45S70S NetworkManager[983]: <info> Starting VPN service 'openvpn'...
Sep 25 20:26:38 NP-Q45S70S NetworkManager[983]: <info> VPN service 'openvpn' started (org.freedesktop.NetworkManager.openvpn), PID 3020
Sep 25 20:26:38 NP-Q45S70S NetworkManager[983]: <info> VPN service 'openvpn' appeared; activating connections
Sep 25 20:26:38 NP-Q45S70S NetworkManager[983]: <info> VPN plugin state changed: init (1)
Sep 25 20:26:38 NP-Q45S70S NetworkManager[983]: <info> VPN plugin state changed: starting (3)
Sep 25 20:26:38 NP-Q45S70S NetworkManager[983]: <info> VPN connection 'AirVPN_United Kingdom_UDP-443' (Connect) reply received.
Sep 25 20:26:38 NP-Q45S70S nm-openvpn[3023]: OpenVPN 2.2.1 i686-linux-gnu [sSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110424-2 (2.2RC2)] built on Feb 27 2013
Sep 25 20:26:38 NP-Q45S70S nm-openvpn[3023]: WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Sep 25 20:26:38 NP-Q45S70S nm-openvpn[3023]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 25 20:26:38 NP-Q45S70S nm-openvpn[3023]: WARNING: file '/home/sam-user1/Downloads/AirVpn/user.key' is group or others accessible
Sep 25 20:26:38 NP-Q45S70S nm-openvpn[3023]: LZO compression initialized
Sep 25 20:26:39 NP-Q45S70S nm-openvpn[3023]: UDPv4 link local: [undef]
Sep 25 20:26:39 NP-Q45S70S nm-openvpn[3023]: UDPv4 link remote: [AF_INET]78.129.153.40:443
Sep 25 20:26:40 NP-Q45S70S nm-openvpn[3023]: [server] Peer Connection Initiated with [AF_INET]78.129.153.40:443
Sep 25 20:26:42 NP-Q45S70S nm-openvpn[3023]: TUN/TAP device tun0 opened
Sep 25 20:26:42 NP-Q45S70S nm-openvpn[3023]: /usr/lib/NetworkManager/nm-openvpn-service-openvpn-helper tun0 1500 1558 10.4.10.2 10.4.10.1 init
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]:    SCPlugin-Ifupdown: devices added (path: /sys/devices/virtual/net/tun0, iface: tun0)
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]:    SCPlugin-Ifupdown: device added (path: /sys/devices/virtual/net/tun0, iface: tun0): no ifupdown configuration found.
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> VPN connection 'AirVPN_United Kingdom_UDP-443' (IP Config Get) reply received.
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> VPN Gateway: 78.129.153.40
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Internal Gateway: 10.4.10.1
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Tunnel Device: tun0
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Internal IP4 Address: 10.4.10.2
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Internal IP4 Prefix: 32
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Internal IP4 Point-to-Point Address: 10.4.10.1
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Maximum Segment Size (MSS): 0
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Static Route: 10.4.0.1/32   Next Hop: 10.4.0.1
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Forbid Default Route: no
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> Internal IP4 DNS: 10.4.0.1
Sep 25 20:26:42 NP-Q45S70S NetworkManager[983]: <info> DNS Domain: '(none)'
Sep 25 20:26:42 NP-Q45S70S nm-openvpn[3023]: Initialization Sequence Completed
Sep 25 20:26:43 NP-Q45S70S NetworkManager[983]: <info> (tun0): writing resolv.conf to /sbin/resolvconf
Sep 25 20:26:43 NP-Q45S70S dnsmasq[1622]: setting upstream servers from DBus
Sep 25 20:26:43 NP-Q45S70S dnsmasq[1622]: using nameserver 10.4.0.1#53
Sep 25 20:26:43 NP-Q45S70S NetworkManager[983]: <info> VPN connection 'AirVPN_United Kingdom_UDP-443' (IP Config Get) complete.
Sep 25 20:26:43 NP-Q45S70S NetworkManager[983]: <info> Policy set 'AirVPN_United Kingdom_UDP-443' (tun0) as default for IPv4 routing and DNS.
Sep 25 20:26:43 NP-Q45S70S dbus[820]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Sep 25 20:26:43 NP-Q45S70S NetworkManager[983]: <info> VPN plugin state changed: started (4)
Sep 25 20:26:43 NP-Q45S70S dbus[820]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 25 20:26:52 NP-Q45S70S ntpdate[3062]: adjust time server 91.189.89.199 offset 0.007848 sec
