Not connected, Your IP: 18.116.118.244
Hi, Ive been using Airvpn for a few years now with now real issues.
About a week ago had problems with Eddie 2:13:6 and connection dropping out because of "server and updates" failing.
Updated yesterday to Eddie 2:15:2 and have similar problems, Eddie will not connect unless I uncheck the "check Airvpn tunnel" in options, had to do this because Eddie kept hanging on checking IPV6 on startup.
When it does connect to any server - I have tried a lot of them along with different protocols - the speed drops to zero very quickly and get the "Cannot retrieve systems & servers data" error
. 2018.07.09 13:15:16 - Eddie version: 2.15.2 / windows_x64, System: Windows, Name: Windows 7 Home Premium, Version: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net: v2.0.50727
. 2018.07.09 13:15:16 - Reading options from C:\Program Files\AirVPN\default.xml
. 2018.07.09 13:15:17 - Command line arguments (0):
. 2018.07.09 13:15:17 - Profile path: C:\Program Files\AirVPN\default.xml
. 2018.07.09 13:15:20 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2018.07.09 13:15:20 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2018.07.09 13:15:20 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2018.07.09 13:15:20 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2018.07.09 13:15:20 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2018.07.09 13:15:20 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
! 2018.07.09 13:15:21 - Activation of Network Lock - Windows Filtering Platform
. 2018.07.09 13:15:21 - Updating systems & servers data ...
I 2018.07.09 13:15:21 - Ready
. 2018.07.09 13:15:22 - Systems & servers data update completed
I 2018.07.09 13:15:29 - Session starting.
I 2018.07.09 13:15:30 - Checking authorization ...
! 2018.07.09 13:15:30 - Connecting to Alathfar (United Kingdom, Maidenhead)
. 2018.07.09 13:15:30 - Routes, added a new route, 185.103.96.146 for gateway 192.168.1.254
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[ui]: Reading configuration from file C:\Program Files\AirVPN\cb1b90540e7095dd0a0a5d83eae2bfeb2ac25471cf9c04369f2b50cb42ccb2ba.tmp.ssl
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[ui]: Initializing service [openvpn]
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[ui]: Configuration successful
. 2018.07.09 13:15:31 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.09 13:15:31 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2018.07.09 13:15:31 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.09 13:15:31 - Connection to OpenVPN Management Interface
. 2018.07.09 13:15:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.09 13:15:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.09 13:15:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.09 13:15:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.09 13:15:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.09 13:15:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:60783
. 2018.07.09 13:15:31 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2018.07.09 13:15:31 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:60783 [nonblock]
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49333
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: s_connect: connecting 185.103.96.146:443
. 2018.07.09 13:15:31 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:60783
. 2018.07.09 13:15:31 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.09 13:15:31 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:60783
. 2018.07.09 13:15:31 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[0]: s_connect: connected 185.103.96.146:443
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.81:49335
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: SNI: sending servername: 185.103.96.146
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: Peer certificate not required
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: Certificate verification disabled
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: Client certificate not requested
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: TLS connected: new session negotiated
. 2018.07.09 13:15:31 - SSL > 2018.07.09 13:15:31 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.09 13:15:31 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:60783, sid=b2b90158 7d1916da
. 2018.07.09 13:15:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.09 13:15:31 - OpenVPN > VERIFY KU OK
. 2018.07.09 13:15:31 - OpenVPN > Validating certificate extended key usage
. 2018.07.09 13:15:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.09 13:15:31 - OpenVPN > VERIFY EKU OK
. 2018.07.09 13:15:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.09 13:15:32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.09 13:15:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:60783
. 2018.07.09 13:15:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.09 13:15:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.5.39.1,dhcp-option DNS6 fde6:7a:7d20:127::1,tun-ipv6,route-gateway 10.5.39.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:127::1000/64 fde6:7a:7d20:127::1,ifconfig 10.5.39.2 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.09 13:15:33 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.09 13:15:33 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.09 13:15:33 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.09 13:15:33 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.09 13:15:33 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.09 13:15:33 - OpenVPN > interactive service msg_channel=0
. 2018.07.09 13:15:33 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=11 HWADDR=00:24:8c:3e:fe:f6
. 2018.07.09 13:15:33 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.09 13:15:33 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2018.07.09 13:15:33 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.09 13:15:33 - OpenVPN > open_tun
. 2018.07.09 13:15:33 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{854F057F-7592-4A70-90F5-0CB7FD030F92}.tap
. 2018.07.09 13:15:33 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.09 13:15:33 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.39.0/10.5.39.2/255.255.255.0 [sUCCEEDED]
. 2018.07.09 13:15:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.39.2/255.255.255.0 on interface {854F057F-7592-4A70-90F5-0CB7FD030F92} [DHCP-serv: 10.5.39.254, lease-time: 31536000]
. 2018.07.09 13:15:33 - OpenVPN > Successful ARP Flush on interface [12] {854F057F-7592-4A70-90F5-0CB7FD030F92}
. 2018.07.09 13:15:33 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.09 13:15:34 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:127::1000 store=active
. 2018.07.09 13:15:35 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:127::1 validate=no
. 2018.07.09 13:15:36 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.07.09 13:15:36 - OpenVPN > add_route_ipv6(fde6:7a:7d20:127::/64 -> fde6:7a:7d20:127::1000 metric 0) dev Local Area Connection 2
. 2018.07.09 13:15:36 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:127::/64 interface=12 fe80::8 store=active
. 2018.07.09 13:15:36 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.09 13:15:41 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.09 13:15:41 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2018.07.09 13:15:41 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2018.07.09 13:15:41 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.09 13:15:41 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.39.1
. 2018.07.09 13:15:41 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.39.1
. 2018.07.09 13:15:41 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:127::1 metric -1) dev Local Area Connection 2
. 2018.07.09 13:15:41 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active
. 2018.07.09 13:15:41 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.09 13:15:41 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:127::1 metric -1) dev Local Area Connection 2
. 2018.07.09 13:15:41 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active
. 2018.07.09 13:15:42 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:127::1 metric -1) dev Local Area Connection 2
. 2018.07.09 13:15:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active
. 2018.07.09 13:15:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.09 13:15:42 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:127::1 metric -1) dev Local Area Connection 2
. 2018.07.09 13:15:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active
. 2018.07.09 13:15:42 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.09 13:15:42 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.09 13:15:42 - DNS leak protection with packet filtering enabled.
. 2018.07.09 13:15:43 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.50.0.1) to 10.5.39.1)
. 2018.07.09 13:15:44 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:127::1)
. 2018.07.09 13:15:44 - Routes, added a new route, 185.103.96.143 for gateway 10.5.39.1
. 2018.07.09 13:15:44 - Routes, added a new route, 2a01:a500:320:52a4:c626:3328:bc3c:1a5f for gateway fde6:7a:7d20:127::1
. 2018.07.09 13:15:44 - Flushing DNS
I 2018.07.09 13:15:51 - Checking DNS
! 2018.07.09 13:15:52 - Connected.
. 2018.07.09 13:15:52 - OpenVPN > Initialization Sequence Completed
. 2018.07.09 13:16:31 - SSL > 2018.07.09 13:16:31 LOG6[cron]: Executing cron jobs
. 2018.07.09 13:16:31 - SSL > 2018.07.09 13:16:31 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.09 13:26:22 - Updating systems & servers data ...
. 2018.07.09 13:27:43 - Cannot retrieve systems & servers data. (curl: (28) Connection timed out after 20000 milliseconds)
Id be very grateful if anyone could take a look at the log and see whats going on, Thanks.
I also have some problems with Eddie and IPV6 today! I can not connect anymore. Until I found the mistake and that is in my eyes, a software bug from AirVPN, that's fact.
As soon as I activate Network Lock, I will not be able to connect to any server and hang up during IPv6 scanning.
But as soon as I deactivate Network Lock, I get a connection with each server at once.
I reported that to the support, with the logs. I'm curious if I get an answer, I'm surprised that you have received no answer and help until today.
Errors happen. If you want help from the community, then please post those same logs here too, as we otherwise don't know what's going on.
Support requires time to analyse an issue before reporting back. Naturally, if there's either a huge amount of support tickets or the issue is somehow complex, you may need to wait slightly longer for a reply.
Until you supply your logs, it would be nice to know if you're using the latest Eddie Stable release or not, as well as more information about your system, such as whether or not you use 3rd party firewall software. .
Thank you.
@LZ1
I opened a support ticket and sent all the logs. However, I have reset the network and now it seems to go again, but comes again a new error .... Unable to compute route185.165. 175.54 IPv4 Nat Gateway not available and I have that with almost all servers of you, with the most different IP addresses.
I spend the whole afternoon with your software. I study and have to study, because I'm going to graduate with exams, but no, now I have to deal with your software and look for mistakes. Not meant bad, but I spent half the afternoon with what I would have to spend learning!
@LZ1
I understand your frustrations.
But as I said before, we need all of your logs too and not simply one line of it, since that's only one small part of the picture.
Here is the log with the routing error IPv4
I 2018.07.10 15:39:59 - Session starting.
I 2018.07.10 15:39:59 - Checking authorization ...
! 2018.07.10 15:39:59 - Connecting to Achird (Switzerland, Zurich)
. 2018.07.10 15:40:00 - Shell(131) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.38 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:40:00 - Shell(131) done in 94 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:40:00 - Routes, added a new route, 185.156.175.38 for gateway 192.168.0.1
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\4c954e111b3a04b8b70e273b6165d0cdcba828fcf6e9ca52b9417b11d6897b13.tmp.ssl
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[ui]: Configuration successful
. 2018.07.10 15:40:00 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:40:00 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:40:00 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:40:00 - Connection to OpenVPN Management Interface
. 2018.07.10 15:40:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:40:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:40:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:40:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:40:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:40:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:11007
. 2018.07.10 15:40:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:40:00 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:11007 [nonblock]
. 2018.07.10 15:40:00 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:11007
. 2018.07.10 15:40:00 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:40:00 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:11007
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50130
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: s_connect: connecting 185.156.175.38:443
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[0]: s_connect: connected 185.156.175.38:443
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50131
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: SNI: sending servername: 185.156.175.38
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: Peer certificate not required
. 2018.07.10 15:40:00 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: Client certificate not requested
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:40:00 - SSL > 2018.07.10 15:40:00 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:40:00 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:11007, sid=3ab6c24c dedc25b8
. 2018.07.10 15:40:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:40:00 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:40:00 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:40:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:40:00 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:40:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:40:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:40:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:11007
. 2018.07.10 15:40:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:40:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.159.1,dhcp-option DNS6 fde6:7a:7d20:9f::1,tun-ipv6,route-gateway 10.4.159.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:9f::1005/64 fde6:7a:7d20:9f::1,ifconfig 10.4.159.7 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:40:02 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:40:02 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:40:02 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:40:02 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:40:02 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:40:02 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:40:02 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:40:02 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:40:02 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:40:02 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:40:02 - OpenVPN > open_tun
. 2018.07.10 15:40:02 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:40:02 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:40:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.159.0/10.4.159.7/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:40:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.159.7/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.4.159.254, lease-time: 31536000]
. 2018.07.10 15:40:02 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:40:02 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:40:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:9f::1005 store=active
. 2018.07.10 15:40:04 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:9f::1 validate=no
. 2018.07.10 15:40:04 - Shell(132) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 15:40:04 - Shell(132) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:40:04 -     Schnittstellenliste
. 2018.07.10 15:40:04 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:40:04 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:40:04 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:40:04 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:40:04 -     ===========================================================================
. 2018.07.10 15:40:04 -     IPv6-Routentabelle
. 2018.07.10 15:40:04 -     Aktive Routen:
. 2018.07.10 15:40:04 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:40:04 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:40:04 -     29    291 fde6:7a:7d20:9f::/64     Auf Verbindung
. 2018.07.10 15:40:04 -     29    291 fde6:7a:7d20:9f::/64     fe80::8
. 2018.07.10 15:40:04 -     29    291 fde6:7a:7d20:9f::1005/128
. 2018.07.10 15:40:04 -     Auf Verbindung
. 2018.07.10 15:40:04 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:04 -     29    291 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:04 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:40:04 -     29    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:40:04 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:04 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:04 -     29    291 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:04 -     St„ndige Routen:
. 2018.07.10 15:40:04 -     Keine'
. 2018.07.10 15:40:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:9f::/64 -> fde6:7a:7d20:9f::1005 metric 0) dev Ethernet 2
. 2018.07.10 15:40:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:9f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:40:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:40:09 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:40:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:40:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:40:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:40:09 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:40:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:40:09 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:40:09 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:40:09 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:40:09 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:40:09 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:40:09 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:40:10 - Shell(133) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 15:40:10 - Shell(133) done in 78 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:40:10 -     Schnittstellenliste
. 2018.07.10 15:40:10 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:40:10 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:40:10 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:40:10 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:40:10 -     ===========================================================================
. 2018.07.10 15:40:10 -     IPv4-Routentabelle
. 2018.07.10 15:40:10 -     Aktive Routen:
. 2018.07.10 15:40:10 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 15:40:10 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 15:40:10 -     0.0.0.0        128.0.0.0       10.4.159.1       10.4.159.7      3
. 2018.07.10 15:40:10 -     10.4.159.0    255.255.255.0   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:10 -     10.4.159.7  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:10 -     10.4.159.255  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:10 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:10 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:10 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 15:40:10 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:10 -     128.0.0.0        128.0.0.0       10.4.159.1       10.4.159.7      3
. 2018.07.10 15:40:10 -     185.156.175.38  255.255.255.255      192.168.0.1    192.168.0.101     26
. 2018.07.10 15:40:10 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:10 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:10 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:10 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:10 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:10 -     224.0.0.0        240.0.0.0   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:10 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:10 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:10 -     255.255.255.255  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:10 -     St„ndige Routen:
. 2018.07.10 15:40:10 -     Keine'
. 2018.07.10 15:40:10 - Shell(134) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 15:40:10 - Shell(134) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:40:10 -     IPv6-Routentabelle
. 2018.07.10 15:40:10 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:40:10 -     29    259 ::/3                     fe80::8
. 2018.07.10 15:40:10 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:40:10 -     29    259 2000::/4                 fe80::8
. 2018.07.10 15:40:10 -     29    259 3000::/4                 fe80::8
. 2018.07.10 15:40:10 -     29    259 fc00::/7                 fe80::8
. 2018.07.10 15:40:10 -     29    259 fde6:7a:7d20:9f::/64     Auf Verbindung
. 2018.07.10 15:40:10 -     29    259 fde6:7a:7d20:9f::/64     fe80::8
. 2018.07.10 15:40:10 -     29    259 fde6:7a:7d20:9f::1005/128
. 2018.07.10 15:40:10 -     Auf Verbindung
. 2018.07.10 15:40:10 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:10 -     29    259 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:10 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:40:10 -     29    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:40:10 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:10 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:10 -     29    259 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:10 - Shell(135) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.4.159.1 register=primary validate=no';
. 2018.07.10 15:40:10 - Shell(135) done in 94 ms, exit: 0
. 2018.07.10 15:40:10 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.4.159.1)
. 2018.07.10 15:40:10 - Shell(136) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:9f::1 register=primary validate=no';
. 2018.07.10 15:40:10 - Shell(136) done in 94 ms, exit: 0
. 2018.07.10 15:40:10 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:9f::1)
. 2018.07.10 15:40:10 - Shell(137) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.35 mask 255.255.255.255 10.4.159.1 if 29';
. 2018.07.10 15:40:10 - Shell(137) done in 32 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:40:10 - Routes, added a new route, 185.156.175.35 for gateway 10.4.159.1
. 2018.07.10 15:40:10 - Shell(138) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2001:ac8:28:3:4a30:c1b3:8485:40c/128" interface="29" nexthop="fde6:7a:7d20:9f::1"';
. 2018.07.10 15:40:10 - Shell(138) done in 93 ms, exit: 0, out: 'OK.'
. 2018.07.10 15:40:10 - Routes, added a new route, 2001:ac8:28:3:4a30:c1b3:8485:40c for gateway fde6:7a:7d20:9f::1
. 2018.07.10 15:40:10 - Flushing DNS
. 2018.07.10 15:40:10 - Shell(139) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 15:40:10 - Shell(139) done in 47 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:40:10 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 15:40:10 - Shell(140) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 15:40:13 - Shell(140) done in 3031 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:40:13 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 15:40:13 - Checking route IPv4
I 2018.07.10 15:40:14 - Checking route IPv6
I 2018.07.10 15:40:17 - Checking DNS
! 2018.07.10 15:40:18 - Connected.
. 2018.07.10 15:40:18 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:40:26 - Disconnecting
. 2018.07.10 15:40:26 - Shell(141) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.38 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:40:26 - Shell(141) done in 62 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:40:26 - Routes, removed a route previously added, 185.156.175.38 for gateway 192.168.0.1
. 2018.07.10 15:40:26 - Shell(142) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.35 mask 255.255.255.255 10.4.159.1 if 29';
. 2018.07.10 15:40:26 - Shell(142) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:40:26 - Routes, removed a route previously added, 185.156.175.35 for gateway 10.4.159.1
. 2018.07.10 15:40:26 - Shell(143) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2001:ac8:28:3:4a30:c1b3:8485:40c/128" interface="29" nexthop="fde6:7a:7d20:9f::1"';
. 2018.07.10 15:40:26 - Shell(143) done in 125 ms, exit: 0, out: 'OK.'
. 2018.07.10 15:40:26 - Routes, removed a route previously added, 2001:ac8:28:3:4a30:c1b3:8485:40c for gateway fde6:7a:7d20:9f::1
. 2018.07.10 15:40:26 - Sending management termination signal
. 2018.07.10 15:40:26 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:40:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:40:27 - SSL > 2018.07.10 15:40:26 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:40:27 - SSL > 2018.07.10 15:40:26 LOG5[0]: Connection reset: 20405 byte(s) sent to TLS, 25737 byte(s) sent to socket
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:40:27 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:40:27 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:40:27 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:40:27 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:40:27 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:40:27 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:40:27 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:40:27 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:9f::/64)
. 2018.07.10 15:40:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:9f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:40:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:9f::1005 store=active
. 2018.07.10 15:40:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:40:27 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:40:27 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:40:36 - Sending soft termination signal
. 2018.07.10 15:40:36 - Connection terminated.
. 2018.07.10 15:40:36 - Shell(144) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 15:40:36 - Shell(144) done in 110 ms, exit: 0
. 2018.07.10 15:40:36 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:40:36 - Shell(145) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 15:40:36 - Shell(145) done in 94 ms, exit: 0
. 2018.07.10 15:40:36 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:40:36 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:40:36 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:40:36 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
. 2018.07.10 15:40:36 - Flushing DNS
. 2018.07.10 15:40:36 - Shell(146) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 15:40:36 - Shell(146) done in 47 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:40:36 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 15:40:36 - Shell(147) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 15:40:39 - Shell(147) done in 3063 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:40:39 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
! 2018.07.10 15:40:40 - Session terminated.
! 2018.07.10 15:40:41 - Activation of Network Lock - Windows Filtering Platform
I 2018.07.10 15:40:45 - Session starting.
I 2018.07.10 15:40:46 - Checking authorization ...
! 2018.07.10 15:40:46 - Connecting to Achird (Switzerland, Zurich)
. 2018.07.10 15:40:46 - Shell(148) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.38 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:40:46 - Shell(148) done in 78 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:40:46 - Routes, added a new route, 185.156.175.38 for gateway 192.168.0.1
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\7efcef140c0889801e64cef85bd6a3f8e001cfb075597e53ff16f18a7296b8ff.tmp.ssl
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[ui]: Configuration successful
. 2018.07.10 15:40:47 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:40:47 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:40:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:40:47 - Connection to OpenVPN Management Interface
. 2018.07.10 15:40:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:40:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:40:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:40:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:40:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:40:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:20305
. 2018.07.10 15:40:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:40:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:20305 [nonblock]
. 2018.07.10 15:40:47 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:20305
. 2018.07.10 15:40:47 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:40:47 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:20305
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50142
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: s_connect: connecting 185.156.175.38:443
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[0]: s_connect: connected 185.156.175.38:443
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50143
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: SNI: sending servername: 185.156.175.38
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: Peer certificate not required
. 2018.07.10 15:40:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: Client certificate not requested
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:40:47 - SSL > 2018.07.10 15:40:47 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:40:47 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:20305, sid=eccd925e 66b05c4d
. 2018.07.10 15:40:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:40:47 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:40:47 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:40:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:40:47 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:40:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:40:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:40:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:20305
. 2018.07.10 15:40:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:40:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.159.1,dhcp-option DNS6 fde6:7a:7d20:9f::1,tun-ipv6,route-gateway 10.4.159.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:9f::1005/64 fde6:7a:7d20:9f::1,ifconfig 10.4.159.7 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:40:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:40:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:40:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:40:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:40:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:40:49 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:40:49 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:40:49 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:40:49 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:40:49 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:40:49 - OpenVPN > open_tun
. 2018.07.10 15:40:49 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:40:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:40:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.159.0/10.4.159.7/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:40:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.159.7/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.4.159.254, lease-time: 31536000]
. 2018.07.10 15:40:49 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:40:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:40:50 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:9f::1005 store=active
. 2018.07.10 15:40:51 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:9f::1 validate=no
. 2018.07.10 15:40:51 - Shell(149) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 15:40:51 - Shell(149) done in 46 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:40:51 -     Schnittstellenliste
. 2018.07.10 15:40:51 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:40:51 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:40:51 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:40:51 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:40:51 -     ===========================================================================
. 2018.07.10 15:40:51 -     IPv6-Routentabelle
. 2018.07.10 15:40:51 -     Aktive Routen:
. 2018.07.10 15:40:51 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:40:51 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:40:51 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:51 -     29    291 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:51 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:40:51 -     Auf Verbindung
. 2018.07.10 15:40:51 -     29    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:40:51 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:51 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:51 -     29    291 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:51 -     St„ndige Routen:
. 2018.07.10 15:40:51 -     Keine'
. 2018.07.10 15:40:51 - OpenVPN > add_route_ipv6(fde6:7a:7d20:9f::/64 -> fde6:7a:7d20:9f::1005 metric 0) dev Ethernet 2
. 2018.07.10 15:40:51 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:9f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:40:51 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:40:56 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:40:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:40:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:40:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:40:56 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:40:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:40:56 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:40:56 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:40:56 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:40:56 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:40:56 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:40:56 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:40:56 - Shell(150) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 15:40:57 - Shell(150) done in 78 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:40:57 -     Schnittstellenliste
. 2018.07.10 15:40:57 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:40:57 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:40:57 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:40:57 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:40:57 -     ===========================================================================
. 2018.07.10 15:40:57 -     IPv4-Routentabelle
. 2018.07.10 15:40:57 -     Aktive Routen:
. 2018.07.10 15:40:57 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 15:40:57 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 15:40:57 -     0.0.0.0        128.0.0.0       10.4.159.1       10.4.159.7      3
. 2018.07.10 15:40:57 -     10.4.159.0    255.255.255.0   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:57 -     10.4.159.7  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:57 -     10.4.159.255  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:57 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:57 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:57 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 15:40:57 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:57 -     128.0.0.0        128.0.0.0       10.4.159.1       10.4.159.7      3
. 2018.07.10 15:40:57 -     185.156.175.38  255.255.255.255      192.168.0.1    192.168.0.101     26
. 2018.07.10 15:40:57 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:57 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:57 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:57 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:57 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:57 -     224.0.0.0        240.0.0.0   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:57 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:40:57 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:40:57 -     255.255.255.255  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 15:40:57 -     St„ndige Routen:
. 2018.07.10 15:40:57 -     Keine'
. 2018.07.10 15:40:57 - Shell(151) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 15:40:57 - Shell(151) done in 62 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:40:57 -     IPv6-Routentabelle
. 2018.07.10 15:40:57 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:40:57 -     29    259 ::/3                     fe80::8
. 2018.07.10 15:40:57 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:40:57 -     29    259 2000::/4                 fe80::8
. 2018.07.10 15:40:57 -     29    259 3000::/4                 fe80::8
. 2018.07.10 15:40:57 -     29    259 fc00::/7                 fe80::8
. 2018.07.10 15:40:57 -     29    259 fde6:7a:7d20:9f::/64     fe80::8
. 2018.07.10 15:40:57 -     29    259 fde6:7a:7d20:9f::1005/128
. 2018.07.10 15:40:57 -     Auf Verbindung
. 2018.07.10 15:40:57 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:57 -     29    259 fe80::/64                Auf Verbindung
. 2018.07.10 15:40:57 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:40:57 -     29    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:40:57 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:57 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:57 -     29    259 ff00::/8                 Auf Verbindung
. 2018.07.10 15:40:57 - Shell(152) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.4.159.1 register=primary validate=no';
. 2018.07.10 15:40:57 - Shell(152) done in 93 ms, exit: 0
. 2018.07.10 15:40:57 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.4.159.1)
. 2018.07.10 15:40:57 - Shell(153) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:9f::1 register=primary validate=no';
. 2018.07.10 15:40:57 - Shell(153) done in 94 ms, exit: 0
. 2018.07.10 15:40:57 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:9f::1)
. 2018.07.10 15:40:57 - Shell(154) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.35 mask 255.255.255.255 10.4.159.1 if 29';
. 2018.07.10 15:40:57 - Shell(154) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:40:57 - Routes, added a new route, 185.156.175.35 for gateway 10.4.159.1
. 2018.07.10 15:40:57 - Shell(155) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2001:ac8:28:3:4a30:c1b3:8485:40c/128" interface="29" nexthop="fde6:7a:7d20:9f::1"';
. 2018.07.10 15:40:57 - Shell(155) done in 94 ms, exit: 0, out: 'OK.'
. 2018.07.10 15:40:57 - Routes, added a new route, 2001:ac8:28:3:4a30:c1b3:8485:40c for gateway fde6:7a:7d20:9f::1
. 2018.07.10 15:40:57 - Flushing DNS
. 2018.07.10 15:40:57 - Shell(156) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 15:40:57 - Shell(156) done in 46 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:40:57 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 15:40:57 - Shell(157) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 15:41:00 - Shell(157) done in 3047 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:41:00 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 15:41:00 - Checking route IPv4
I 2018.07.10 15:41:00 - Checking route IPv6
. 2018.07.10 15:41:21 - curl: (28) Connection timed out after 20015 milliseconds - Stack:    bei Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.07.10 15:41:21 -     bei Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.07.10 15:41:21 -     bei Eddie.Core.Threads.Session.ConnectedStep()
. 2018.07.10 15:41:21 - Checking route (2° try)
. 2018.07.10 15:41:42 - curl: (28) Connection timed out after 20015 milliseconds - Stack:    bei Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.07.10 15:41:42 -     bei Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.07.10 15:41:42 -     bei Eddie.Core.Threads.Session.ConnectedStep()
. 2018.07.10 15:41:42 - Checking route (3° try)
. 2018.07.10 15:41:52 - Updating systems & servers data ...
. 2018.07.10 15:41:53 - Systems & servers data update completed
. 2018.07.10 15:42:04 - curl: (28) Connection timed out after 20000 milliseconds - Stack:    bei Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.07.10 15:42:04 -     bei Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.07.10 15:42:04 -     bei Eddie.Core.Threads.Session.ConnectedStep()
E 2018.07.10 15:42:04 - Checking route IPv6 failed.
. 2018.07.10 15:42:04 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:42:04 - Disconnecting
. 2018.07.10 15:42:04 - Shell(158) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.38 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:42:04 - Shell(158) done in 109 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:42:04 - Routes, removed a route previously added, 185.156.175.38 for gateway 192.168.0.1
. 2018.07.10 15:42:04 - Shell(159) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.35 mask 255.255.255.255 10.4.159.1 if 29';
. 2018.07.10 15:42:04 - Shell(159) done in 62 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:42:04 - Routes, removed a route previously added, 185.156.175.35 for gateway 10.4.159.1
. 2018.07.10 15:42:04 - Shell(160) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2001:ac8:28:3:4a30:c1b3:8485:40c/128" interface="29" nexthop="fde6:7a:7d20:9f::1"';
. 2018.07.10 15:42:04 - Shell(160) done in 156 ms, exit: 0, out: 'OK.'
. 2018.07.10 15:42:04 - Routes, removed a route previously added, 2001:ac8:28:3:4a30:c1b3:8485:40c for gateway fde6:7a:7d20:9f::1
. 2018.07.10 15:42:04 - SSL > 2018.07.10 15:41:47 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:42:04 - SSL > 2018.07.10 15:41:47 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:42:04 - Sending management termination signal
. 2018.07.10 15:42:04 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:42:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:42:04 - SSL > 2018.07.10 15:42:04 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:42:04 - SSL > 2018.07.10 15:42:04 LOG5[0]: Connection reset: 12302 byte(s) sent to TLS, 123106 byte(s) sent to socket
. 2018.07.10 15:42:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:42:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:42:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:42:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 15:42:04 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:42:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:42:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:42:04 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:42:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:42:04 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:42:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:42:05 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:42:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:42:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:42:05 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:42:05 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:9f::/64)
. 2018.07.10 15:42:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:9f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:42:05 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:9f::1005 store=active
. 2018.07.10 15:42:05 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:42:05 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:42:05 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:42:14 - Sending soft termination signal
. 2018.07.10 15:42:14 - Connection terminated.
. 2018.07.10 15:42:14 - Shell(161) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 15:42:14 - Shell(161) done in 125 ms, exit: 0
. 2018.07.10 15:42:14 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:42:14 - Shell(162) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 15:42:14 - Shell(162) done in 109 ms, exit: 0
. 2018.07.10 15:42:14 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:42:14 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:42:14 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:42:14 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:42:17 - Checking authorization ...
! 2018.07.10 15:42:18 - Connecting to Pyxis (Netherlands, Alblasserdam)
. 2018.07.10 15:42:18 - Shell(163) of 'cmd.exe', 2 args: '/c';'route add 213.152.161.237 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:42:18 - Shell(163) done in 63 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:42:18 - Routes, added a new route, 213.152.161.237 for gateway 192.168.0.1
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\57049556d04919ccca87f4dea8e4ee54eaebbe8c31ef9469409ede7ae985b0c2.tmp.ssl
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[ui]: Configuration successful
. 2018.07.10 15:42:18 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:42:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:42:18 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:42:18 - Connection to OpenVPN Management Interface
. 2018.07.10 15:42:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:42:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:42:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:42:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:42:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:42:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:22713
. 2018.07.10 15:42:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:42:18 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:22713 [nonblock]
. 2018.07.10 15:42:18 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:22713
. 2018.07.10 15:42:18 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:42:18 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:22713
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50182
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG6[0]: s_connect: connecting 213.152.161.237:443
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[0]: s_connect: connected 213.152.161.237:443
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50183
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG6[0]: SNI: sending servername: 213.152.161.237
. 2018.07.10 15:42:18 - SSL > 2018.07.10 15:42:18 LOG6[0]: Peer certificate not required
. 2018.07.10 15:42:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:42:19 - SSL > 2018.07.10 15:42:18 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:42:19 - SSL > 2018.07.10 15:42:18 LOG6[0]: Client certificate not requested
. 2018.07.10 15:42:19 - SSL > 2018.07.10 15:42:19 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:42:19 - SSL > 2018.07.10 15:42:19 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:42:19 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:22713, sid=5511e18c 3429cbf0
. 2018.07.10 15:42:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:42:19 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:42:19 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:42:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:42:19 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:42:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pyxis, emailAddress=info@airvpn.org
. 2018.07.10 15:42:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:42:19 - OpenVPN > [Pyxis] Peer Connection Initiated with [AF_INET]127.0.0.1:22713
. 2018.07.10 15:42:20 - OpenVPN > SENT CONTROL [Pyxis]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:42:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.27.159.1,dhcp-option DNS6 fde6:7a:7d20:179f::1,tun-ipv6,route-gateway 10.27.159.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:179f::1006/64 fde6:7a:7d20:179f::1,ifconfig 10.27.159.8 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:42:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:42:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:42:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:42:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:42:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:42:20 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:42:20 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:42:20 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:42:20 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:42:20 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:42:20 - OpenVPN > open_tun
. 2018.07.10 15:42:20 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:42:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:42:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.27.159.0/10.27.159.8/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:42:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.27.159.8/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.27.159.254, lease-time: 31536000]
. 2018.07.10 15:42:20 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:42:20 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:42:21 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:179f::1006 store=active
. 2018.07.10 15:42:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:179f::1 validate=no
. 2018.07.10 15:42:22 - Shell(164) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 15:42:22 - Shell(164) done in 63 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:42:22 -     Schnittstellenliste
. 2018.07.10 15:42:22 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:42:22 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:42:22 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:42:22 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:42:22 -     ===========================================================================
. 2018.07.10 15:42:22 -     IPv6-Routentabelle
. 2018.07.10 15:42:22 -     Aktive Routen:
. 2018.07.10 15:42:22 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:42:22 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:42:22 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:42:22 -     29    291 fe80::/64                Auf Verbindung
. 2018.07.10 15:42:22 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:42:22 -     Auf Verbindung
. 2018.07.10 15:42:22 -     29    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:42:22 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:22 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:22 -     29    291 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:22 -     St„ndige Routen:
. 2018.07.10 15:42:22 -     Keine'
. 2018.07.10 15:42:22 - OpenVPN > add_route_ipv6(fde6:7a:7d20:179f::/64 -> fde6:7a:7d20:179f::1006 metric 0) dev Ethernet 2
. 2018.07.10 15:42:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:179f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:42:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
! 2018.07.10 15:42:26 - Disconnecting
. 2018.07.10 15:42:26 - Shell(165) of 'cmd.exe', 2 args: '/c';'route delete 213.152.161.237 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:42:26 - Shell(165) done in 62 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:42:26 - Routes, removed a route previously added, 213.152.161.237 for gateway 192.168.0.1
. 2018.07.10 15:42:26 - Sending management termination signal
. 2018.07.10 15:42:26 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:42:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:42:26 - SSL > 2018.07.10 15:42:26 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:42:26 - SSL > 2018.07.10 15:42:26 LOG5[0]: Connection reset: 4595 byte(s) sent to TLS, 5870 byte(s) sent to socket
. 2018.07.10 15:42:26 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:42:26 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:179f::/64)
. 2018.07.10 15:42:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:179f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:42:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:179f::1006 store=active
. 2018.07.10 15:42:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:42:26 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:42:26 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:42:36 - Sending soft termination signal
. 2018.07.10 15:42:36 - Connection terminated.
I 2018.07.10 15:42:36 - Cancel requested.
! 2018.07.10 15:42:36 - Session terminated.
! 2018.07.10 15:42:37 - Deactivation of Network Lock
I 2018.07.10 15:42:42 - Session starting.
I 2018.07.10 15:42:43 - Checking authorization ...
! 2018.07.10 15:42:43 - Connecting to Baiten (Switzerland, Zurich)
. 2018.07.10 15:42:43 - Shell(166) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.54 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 15:42:43 - Shell(166) done in 79 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:42:43 - Routes, added a new route, 185.156.175.54 for gateway 192.168.0.1
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\e5f95d3aef86bd346cc83fc86349285fb4c2a84542a4ef1c0b21bfbc9f0f6d08.tmp.ssl
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:42:43 - SSL > 2018.07.10 15:42:43 LOG5[ui]: Configuration successful
. 2018.07.10 15:42:43 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:42:43 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:42:43 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:42:43 - Connection to OpenVPN Management Interface
. 2018.07.10 15:42:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:42:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:42:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:42:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:42:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:42:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:2052
. 2018.07.10 15:42:44 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:42:44 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:2052 [nonblock]
. 2018.07.10 15:42:44 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:2052
. 2018.07.10 15:42:44 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:42:44 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:2052
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:43 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50191
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:43 LOG6[0]: s_connect: connecting 185.156.175.54:443
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:43 LOG5[0]: s_connect: connected 185.156.175.54:443
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:43 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50192
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:43 LOG6[0]: SNI: sending servername: 185.156.175.54
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:43 LOG6[0]: Peer certificate not required
. 2018.07.10 15:42:44 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:44 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:44 LOG6[0]: Client certificate not requested
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:44 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:42:44 - SSL > 2018.07.10 15:42:44 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:42:44 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:2052, sid=5d39bc66 cf31520c
. 2018.07.10 15:42:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:42:44 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:42:44 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:42:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:42:44 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:42:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:42:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:42:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:2052
. 2018.07.10 15:42:45 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:42:45 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.11.95.1,dhcp-option DNS6 fde6:7a:7d20:75f::1,tun-ipv6,route-gateway 10.11.95.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:75f::1004/64 fde6:7a:7d20:75f::1,ifconfig 10.11.95.6 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:42:45 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:42:45 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:42:45 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:42:45 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:42:45 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:42:45 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:42:45 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:42:45 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:42:45 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:42:45 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:42:45 - OpenVPN > open_tun
. 2018.07.10 15:42:45 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:42:45 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:42:45 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.11.95.0/10.11.95.6/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:42:45 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.11.95.6/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.11.95.254, lease-time: 31536000]
. 2018.07.10 15:42:45 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:42:45 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:42:46 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:75f::1004 store=active
. 2018.07.10 15:42:47 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:75f::1 validate=no
. 2018.07.10 15:42:48 - Shell(167) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 15:42:48 - Shell(167) done in 46 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:42:48 -     Schnittstellenliste
. 2018.07.10 15:42:48 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:42:48 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:42:48 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:42:48 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:42:48 -     ===========================================================================
. 2018.07.10 15:42:48 -     IPv6-Routentabelle
. 2018.07.10 15:42:48 -     Aktive Routen:
. 2018.07.10 15:42:48 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:42:48 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:42:48 -     29    291 fde6:7a:7d20:75f::/64    fe80::8
. 2018.07.10 15:42:48 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:42:48 -     29    291 fe80::/64                Auf Verbindung
. 2018.07.10 15:42:48 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:42:48 -     Auf Verbindung
. 2018.07.10 15:42:48 -     29    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:42:48 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:48 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:48 -     29    291 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:48 -     St„ndige Routen:
. 2018.07.10 15:42:48 -     Keine'
. 2018.07.10 15:42:48 - OpenVPN > add_route_ipv6(fde6:7a:7d20:75f::/64 -> fde6:7a:7d20:75f::1004 metric 0) dev Ethernet 2
. 2018.07.10 15:42:48 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:75f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:42:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:42:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:42:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:42:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 15:42:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 15:42:54 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:42:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:42:54 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:42:54 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:42:54 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:42:54 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:42:54 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:42:54 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:42:54 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:42:54 - Shell(168) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 15:42:54 - Shell(168) done in 94 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:42:54 -     Schnittstellenliste
. 2018.07.10 15:42:54 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 15:42:54 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 15:42:54 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 15:42:54 -     1...........................Software Loopback Interface 1
. 2018.07.10 15:42:54 -     ===========================================================================
. 2018.07.10 15:42:54 -     IPv4-Routentabelle
. 2018.07.10 15:42:54 -     Aktive Routen:
. 2018.07.10 15:42:54 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 15:42:54 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 15:42:54 -     0.0.0.0        128.0.0.0       10.11.95.1       10.11.95.6      3
. 2018.07.10 15:42:54 -     10.11.95.0    255.255.255.0   Auf Verbindung        10.11.95.6    259
. 2018.07.10 15:42:54 -     10.11.95.6  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 15:42:54 -     10.11.95.255  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 15:42:54 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:42:54 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:42:54 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 15:42:54 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:42:54 -     128.0.0.0        128.0.0.0       10.11.95.1       10.11.95.6      3
. 2018.07.10 15:42:54 -     185.156.175.54  255.255.255.255      192.168.0.1    192.168.0.101     26
. 2018.07.10 15:42:54 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:42:54 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:42:54 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:42:54 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:42:54 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:42:54 -     224.0.0.0        240.0.0.0   Auf Verbindung        10.11.95.6    259
. 2018.07.10 15:42:54 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 15:42:54 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 15:42:54 -     255.255.255.255  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 15:42:54 -     St„ndige Routen:
. 2018.07.10 15:42:54 -     Keine'
. 2018.07.10 15:42:54 - Shell(169) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 15:42:54 - Shell(169) done in 46 ms, exit: 0, out: '===========================================================================
. 2018.07.10 15:42:54 -     IPv6-Routentabelle
. 2018.07.10 15:42:54 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 15:42:54 -     29    259 ::/3                     fe80::8
. 2018.07.10 15:42:54 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 15:42:54 -     29    259 2000::/4                 fe80::8
. 2018.07.10 15:42:54 -     29    259 3000::/4                 fe80::8
. 2018.07.10 15:42:54 -     29    259 fc00::/7                 fe80::8
. 2018.07.10 15:42:54 -     29    259 fde6:7a:7d20:75f::/64    fe80::8
. 2018.07.10 15:42:54 -     29    259 fde6:7a:7d20:75f::1004/128
. 2018.07.10 15:42:54 -     Auf Verbindung
. 2018.07.10 15:42:54 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 15:42:54 -     29    259 fe80::/64                Auf Verbindung
. 2018.07.10 15:42:54 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 15:42:54 -     29    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 15:42:54 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:54 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:54 -     29    259 ff00::/8                 Auf Verbindung
. 2018.07.10 15:42:54 - Shell(170) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.11.95.1 register=primary validate=no';
. 2018.07.10 15:42:54 - Shell(170) done in 109 ms, exit: 0
. 2018.07.10 15:42:54 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.11.95.1)
. 2018.07.10 15:42:54 - Shell(171) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:75f::1 register=primary validate=no';
. 2018.07.10 15:42:54 - Shell(171) done in 94 ms, exit: 0
. 2018.07.10 15:42:54 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:75f::1)
. 2018.07.10 15:42:54 - Shell(172) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.51 mask 255.255.255.255 10.11.95.1 if 29';
. 2018.07.10 15:42:54 - Shell(172) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 15:42:54 - Routes, added a new route, 185.156.175.51 for gateway 10.11.95.1
. 2018.07.10 15:42:54 - Shell(173) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2001:ac8:28:5:6fae:73b:958e:2b90/128" interface="29" nexthop="fde6:7a:7d20:75f::1"';
. 2018.07.10 15:42:55 - Shell(173) done in 94 ms, exit: 0, out: 'OK.'
. 2018.07.10 15:42:55 - Routes, added a new route, 2001:ac8:28:5:6fae:73b:958e:2b90 for gateway fde6:7a:7d20:75f::1
. 2018.07.10 15:42:55 - Flushing DNS
. 2018.07.10 15:42:55 - Shell(174) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 15:42:55 - Shell(174) done in 46 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:42:55 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 15:42:55 - Shell(175) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 15:42:58 - Shell(175) done in 3063 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 15:42:58 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 15:42:58 - Checking route IPv4
I 2018.07.10 15:42:58 - Checking route IPv6
I 2018.07.10 15:43:02 - Checking DNS
! 2018.07.10 15:43:02 - Connected.
. 2018.07.10 15:43:02 - OpenVPN > Initialization Sequence Completed
. 2018.07.10 15:43:43 - SSL > 2018.07.10 15:43:43 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:43:43 - SSL > 2018.07.10 15:43:43 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:52:50 - Updating systems & servers data ...
. 2018.07.10 15:52:51 - Systems & servers data update completed
. 2018.07.10 16:03:47 - Updating systems & servers data ...
. 2018.07.10 16:03:48 - Systems & servers data update completed
. 2018.07.10 16:14:45 - Updating systems & servers data ...
. 2018.07.10 16:14:46 - Systems & servers data update completed
! 2018.07.10 16:16:10 - Disconnecting
. 2018.07.10 16:16:10 - Shell(176) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.54 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 16:16:10 - Shell(176) done in 78 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:16:10 - Routes, removed a route previously added, 185.156.175.54 for gateway 192.168.0.1
. 2018.07.10 16:16:10 - Shell(177) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.51 mask 255.255.255.255 10.11.95.1 if 29';
. 2018.07.10 16:16:10 - Shell(177) done in 78 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:16:10 - Routes, removed a route previously added, 185.156.175.51 for gateway 10.11.95.1
. 2018.07.10 16:16:10 - Shell(178) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2001:ac8:28:5:6fae:73b:958e:2b90/128" interface="29" nexthop="fde6:7a:7d20:75f::1"';
. 2018.07.10 16:16:11 - Shell(178) done in 125 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:16:11 - Routes, removed a route previously added, 2001:ac8:28:5:6fae:73b:958e:2b90 for gateway fde6:7a:7d20:75f::1
. 2018.07.10 16:16:11 - Sending management termination signal
. 2018.07.10 16:16:11 - Management - Send 'signal SIGTERM'
. 2018.07.10 16:16:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 16:16:11 - SSL > 2018.07.10 16:16:11 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 16:16:11 - SSL > 2018.07.10 16:16:11 LOG5[0]: Connection reset: 2316058 byte(s) sent to TLS, 11226010 byte(s) sent to socket
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:16:11 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:16:11 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 16:16:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:16:11 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 16:16:11 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 16:16:11 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 16:16:11 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 16:16:11 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:75f::/64)
. 2018.07.10 16:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:75f::/64 interface=29 fe80::8 store=active
. 2018.07.10 16:16:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:75f::1004 store=active
. 2018.07.10 16:16:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 16:16:11 - OpenVPN > TAP: DHCP address released
. 2018.07.10 16:16:11 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 16:16:20 - Sending soft termination signal
. 2018.07.10 16:16:20 - Connection terminated.
. 2018.07.10 16:16:20 - Shell(179) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:16:20 - Shell(179) done in 125 ms, exit: 0
. 2018.07.10 16:16:20 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:16:20 - Shell(180) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:16:20 - Shell(180) done in 109 ms, exit: 0
. 2018.07.10 16:16:20 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:16:20 - DNS leak protection with packet filtering disabled.
. 2018.07.10 16:16:20 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 16:16:20 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
. 2018.07.10 16:16:20 - Flushing DNS
. 2018.07.10 16:16:20 - Shell(181) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:16:20 - Shell(181) done in 47 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:16:20 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:16:20 - Shell(182) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:16:23 - Shell(182) done in 3063 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:16:23 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
! 2018.07.10 16:16:23 - Session terminated.
! 2018.07.10 16:16:33 - Activation of Network Lock - Windows Filtering Platform
I 2018.07.10 16:16:45 - Session starting.
I 2018.07.10 16:16:46 - Checking authorization ...
! 2018.07.10 16:16:46 - Connecting to Baiten (Switzerland, Zurich)
. 2018.07.10 16:16:46 - Shell(183) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.54 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 16:16:46 - Shell(183) done in 78 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:16:46 - Routes, added a new route, 185.156.175.54 for gateway 192.168.0.1
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\e4b124a57a91b2422a23e00bb6303208c46744616146caf8141dafb0fe10279c.tmp.ssl
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:46 LOG5[ui]: Configuration successful
. 2018.07.10 16:16:47 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:16:47 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 16:16:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:16:47 - Connection to OpenVPN Management Interface
. 2018.07.10 16:16:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 16:16:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:16:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:16:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:16:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:16:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:54051
. 2018.07.10 16:16:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 16:16:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:54051 [nonblock]
. 2018.07.10 16:16:47 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:54051
. 2018.07.10 16:16:47 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 16:16:47 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:54051
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50461
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: s_connect: connecting 185.156.175.54:443
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG5[0]: s_connect: connected 185.156.175.54:443
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50462
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: SNI: sending servername: 185.156.175.54
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: Peer certificate not required
. 2018.07.10 16:16:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: Certificate verification disabled
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: Client certificate not requested
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 16:16:47 - SSL > 2018.07.10 16:16:47 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 16:16:47 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:54051, sid=49d87da9 1f65b03e
. 2018.07.10 16:16:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 16:16:47 - OpenVPN > VERIFY KU OK
. 2018.07.10 16:16:47 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 16:16:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 16:16:47 - OpenVPN > VERIFY EKU OK
. 2018.07.10 16:16:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 16:16:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 16:16:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:54051
. 2018.07.10 16:16:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 16:16:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.11.95.1,dhcp-option DNS6 fde6:7a:7d20:75f::1,tun-ipv6,route-gateway 10.11.95.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:75f::1004/64 fde6:7a:7d20:75f::1,ifconfig 10.11.95.6 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 16:16:48 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 16:16:48 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 16:16:48 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 16:16:48 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:16:48 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:16:48 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 16:16:48 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 16:16:48 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 16:16:48 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 16:16:48 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 16:16:48 - OpenVPN > open_tun
. 2018.07.10 16:16:48 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 16:16:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 16:16:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.11.95.0/10.11.95.6/255.255.255.0 [SUCCEEDED]
. 2018.07.10 16:16:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.11.95.6/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.11.95.254, lease-time: 31536000]
. 2018.07.10 16:16:49 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 16:16:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 16:16:49 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:75f::1004 store=active
. 2018.07.10 16:16:51 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:75f::1 validate=no
. 2018.07.10 16:16:51 - Shell(184) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 16:16:51 - Shell(184) done in 62 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:16:51 -     Schnittstellenliste
. 2018.07.10 16:16:51 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:16:51 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:16:51 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:16:51 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:16:51 -     ===========================================================================
. 2018.07.10 16:16:51 -     IPv6-Routentabelle
. 2018.07.10 16:16:51 -     Aktive Routen:
. 2018.07.10 16:16:51 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:16:51 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:16:51 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:16:51 -     29    291 fe80::/64                Auf Verbindung
. 2018.07.10 16:16:51 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 16:16:51 -     Auf Verbindung
. 2018.07.10 16:16:51 -     29    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:16:51 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:16:51 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:16:51 -     29    291 ff00::/8                 Auf Verbindung
. 2018.07.10 16:16:51 -     St„ndige Routen:
. 2018.07.10 16:16:51 -     Keine'
. 2018.07.10 16:16:51 - OpenVPN > add_route_ipv6(fde6:7a:7d20:75f::/64 -> fde6:7a:7d20:75f::1004 metric 0) dev Ethernet 2
. 2018.07.10 16:16:51 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:75f::/64 interface=29 fe80::8 store=active
. 2018.07.10 16:16:51 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:16:56 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:16:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 16:16:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:16:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:16:56 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 16:16:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:16:56 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 16:16:56 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 16:16:56 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:16:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 16:16:56 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 16:16:56 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 16:16:56 - DNS leak protection with packet filtering enabled.
. 2018.07.10 16:16:56 - Shell(185) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 16:16:56 - Shell(185) done in 93 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:16:56 -     Schnittstellenliste
. 2018.07.10 16:16:56 -     29...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:16:56 -     13...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:16:56 -     16...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:16:56 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:16:56 -     ===========================================================================
. 2018.07.10 16:16:56 -     IPv4-Routentabelle
. 2018.07.10 16:16:56 -     Aktive Routen:
. 2018.07.10 16:16:56 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 16:16:56 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:16:56 -     0.0.0.0        128.0.0.0       10.11.95.1       10.11.95.6      3
. 2018.07.10 16:16:56 -     10.11.95.0    255.255.255.0   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:16:56 -     10.11.95.6  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:16:56 -     10.11.95.255  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:16:56 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:16:56 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:16:56 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:16:56 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:16:56 -     128.0.0.0        128.0.0.0       10.11.95.1       10.11.95.6      3
. 2018.07.10 16:16:56 -     185.156.175.54  255.255.255.255      192.168.0.1    192.168.0.101     26
. 2018.07.10 16:16:56 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:16:56 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:16:56 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:16:56 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:16:56 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:16:56 -     224.0.0.0        240.0.0.0   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:16:56 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:16:56 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:16:56 -     255.255.255.255  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:16:56 -     St„ndige Routen:
. 2018.07.10 16:16:56 -     Keine'
. 2018.07.10 16:16:56 - Shell(186) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 16:16:56 - Shell(186) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:16:56 -     IPv6-Routentabelle
. 2018.07.10 16:16:56 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:16:56 -     29    259 ::/3                     fe80::8
. 2018.07.10 16:16:56 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:16:56 -     29    259 2000::/4                 fe80::8
. 2018.07.10 16:16:56 -     29    259 3000::/4                 fe80::8
. 2018.07.10 16:16:56 -     29    259 fc00::/7                 fe80::8
. 2018.07.10 16:16:56 -     29    259 fde6:7a:7d20:75f::/64    fe80::8
. 2018.07.10 16:16:56 -     29    259 fde6:7a:7d20:75f::1004/128
. 2018.07.10 16:16:56 -     Auf Verbindung
. 2018.07.10 16:16:56 -     13    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:16:56 -     29    259 fe80::/64                Auf Verbindung
. 2018.07.10 16:16:56 -     13    281 fe80::d5d:40bc:2b:df45/128
. 2018.07.10 16:16:56 -     29    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:16:56 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:16:56 -     13    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:16:56 -     29    259 ff00::/8                 Auf Verbindung
. 2018.07.10 16:16:56 - Shell(187) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.11.95.1 register=primary validate=no';
. 2018.07.10 16:16:56 - Shell(187) done in 94 ms, exit: 0
. 2018.07.10 16:16:56 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.11.95.1)
. 2018.07.10 16:16:56 - Shell(188) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:75f::1 register=primary validate=no';
. 2018.07.10 16:16:57 - Shell(188) done in 109 ms, exit: 0
. 2018.07.10 16:16:57 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:75f::1)
. 2018.07.10 16:16:57 - Shell(189) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.51 mask 255.255.255.255 10.11.95.1 if 29';
. 2018.07.10 16:16:57 - Shell(189) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:16:57 - Routes, added a new route, 185.156.175.51 for gateway 10.11.95.1
. 2018.07.10 16:16:57 - Shell(190) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2001:ac8:28:5:6fae:73b:958e:2b90/128" interface="29" nexthop="fde6:7a:7d20:75f::1"';
. 2018.07.10 16:16:57 - Shell(190) done in 109 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:16:57 - Routes, added a new route, 2001:ac8:28:5:6fae:73b:958e:2b90 for gateway fde6:7a:7d20:75f::1
. 2018.07.10 16:16:57 - Flushing DNS
. 2018.07.10 16:16:57 - Shell(191) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:16:57 - Shell(191) done in 31 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:16:57 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:16:57 - Shell(192) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:17:00 - Shell(192) done in 3078 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:17:00 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 16:17:00 - Checking route IPv4
I 2018.07.10 16:17:00 - Checking route IPv6
. 2018.07.10 16:17:20 - curl: (28) Connection timed out after 20016 milliseconds - Stack:    bei Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.07.10 16:17:20 -     bei Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.07.10 16:17:20 -     bei Eddie.Core.Threads.Session.ConnectedStep()
. 2018.07.10 16:17:20 - Checking route (2° try)
. 2018.07.10 16:17:41 - curl: (28) Connection timed out after 20016 milliseconds - Stack:    bei Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.07.10 16:17:41 -     bei Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.07.10 16:17:41 -     bei Eddie.Core.Threads.Session.ConnectedStep()
. 2018.07.10 16:17:41 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 16:17:41 - Disconnecting
. 2018.07.10 16:17:41 - Shell(193) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.54 mask 255.255.255.255 192.168.0.1 if 13';
. 2018.07.10 16:17:41 - Shell(193) done in 78 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:17:41 - Routes, removed a route previously added, 185.156.175.54 for gateway 192.168.0.1
. 2018.07.10 16:17:42 - Shell(194) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.51 mask 255.255.255.255 10.11.95.1 if 29';
. 2018.07.10 16:17:42 - Shell(194) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:17:42 - Routes, removed a route previously added, 185.156.175.51 for gateway 10.11.95.1
. 2018.07.10 16:17:42 - Shell(195) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2001:ac8:28:5:6fae:73b:958e:2b90/128" interface="29" nexthop="fde6:7a:7d20:75f::1"';
. 2018.07.10 16:17:42 - Shell(195) done in 109 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:17:42 - Routes, removed a route previously added, 2001:ac8:28:5:6fae:73b:958e:2b90 for gateway fde6:7a:7d20:75f::1
. 2018.07.10 16:17:42 - Sending management termination signal
. 2018.07.10 16:17:42 - Management - Send 'signal SIGTERM'
. 2018.07.10 16:17:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 16:17:42 - SSL > 2018.07.10 16:17:42 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:17:42 - SSL > 2018.07.10 16:17:42 LOG5[0]: Connection reset: 8405 byte(s) sent to TLS, 17442 byte(s) sent to socket
. 2018.07.10 16:17:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:17:42 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 16:17:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:17:42 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 16:17:42 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 16:17:42 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 16:17:42 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 16:17:42 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:75f::/64)
. 2018.07.10 16:17:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:75f::/64 interface=29 fe80::8 store=active
. 2018.07.10 16:17:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:75f::1004 store=active
. 2018.07.10 16:17:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 16:17:42 - OpenVPN > TAP: DHCP address released
. 2018.07.10 16:17:42 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 16:17:46 - SSL > 2018.07.10 16:17:46 LOG6[cron]: Executing cron jobs
. 2018.07.10 16:17:46 - SSL > 2018.07.10 16:17:46 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 16:17:51 - Sending soft termination signal
. 2018.07.10 16:17:51 - Connection terminated.
. 2018.07.10 16:17:51 - Shell(196) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:17:51 - Shell(196) done in 94 ms, exit: 0
. 2018.07.10 16:17:51 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:17:51 - Shell(197) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:17:51 - Shell(197) done in 109 ms, exit: 0
. 2018.07.10 16:17:51 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:17:51 - DNS leak protection with packet filtering disabled.
. 2018.07.10 16:17:51 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 16:17:51 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 16:17:51 - Cancel requested.
! 2018.07.10 16:17:51 - Session terminated.
. 2018.07.10 16:19:53 - Command line arguments (1): path="home"
. 2018.07.10 16:19:53 - Profile path: C:\Users\gerha\AppData\Local\AirVPN\default.xml
. 2018.07.10 16:19:53 - Shell(1) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 16:19:54 - Shell(1) done in 203 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:19:54 -     Schnittstellenliste
. 2018.07.10 16:19:54 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:19:54 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:19:54 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:19:54 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:19:54 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:19:54 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:19:54 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:19:54 -     ===========================================================================
. 2018.07.10 16:19:54 -     IPv4-Routentabelle
. 2018.07.10 16:19:54 -     Aktive Routen:
. 2018.07.10 16:19:54 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 16:19:54 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:19:54 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:19:54 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:19:54 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:19:54 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:19:54 -     St„ndige Routen:
. 2018.07.10 16:19:54 -     Keine'
. 2018.07.10 16:19:54 - Shell(2) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 16:19:54 - Shell(2) done in 187 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:19:54 -     IPv6-Routentabelle
. 2018.07.10 16:19:54 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:19:54 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:19:54 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:19:55 - Shell(3) of 'C:\Program Files\AirVPN\openvpn.exe', 1 args: '--version';
. 2018.07.10 16:19:56 - Shell(3) done in 125 ms, exit: 1, out: 'OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:19:56 -     library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:19:56 -     Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 16:19:56 -     Originally developed by James Yonan
. 2018.07.10 16:19:56 -     Copyright (C) 2002-2018 OpenVPN Inc <sales@openvpn.net>
. 2018.07.10 16:19:56 -     Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=no enable_plugin_down_root=no enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=yes enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_special_build= with_sysroot=no'
. 2018.07.10 16:19:56 - Shell(4) of 'C:\Program Files\AirVPN\plink.exe', 1 args: '-V';
. 2018.07.10 16:19:56 - Shell(4) done in 93 ms, exit: 1, out: 'plink: Release 0.67'
. 2018.07.10 16:19:56 - Shell(5) of 'C:\Program Files\AirVPN\stunnel.exe', 1 args: '-version';
. 2018.07.10 16:19:56 - Shell(5) done in 125 ms, exit: 0, err: 'stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:19:56 -     Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:19:56 -     Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:19:56 -     Global options:
. 2018.07.10 16:19:56 -     RNDbytes               = 64
. 2018.07.10 16:19:56 -     RNDoverwrite           = yes
. 2018.07.10 16:19:56 -     taskbar                = yes
. 2018.07.10 16:19:56 -     Service-level options:
. 2018.07.10 16:19:56 -     ciphers                = HIGH:!DH:!aNULL:!SSLv2
. 2018.07.10 16:19:56 -     curve                  = prime256v1
. 2018.07.10 16:19:56 -     debug                  = notice
. 2018.07.10 16:19:56 -     logId                  = sequential
. 2018.07.10 16:19:56 -     options                = NO_SSLv2
. 2018.07.10 16:19:56 -     options                = NO_SSLv3
. 2018.07.10 16:19:56 -     sessionCacheSize       = 1000
. 2018.07.10 16:19:56 -     sessionCacheTimeout    = 300 seconds
. 2018.07.10 16:19:56 -     stack                  = 65536 bytes
. 2018.07.10 16:19:56 -     TIMEOUTbusy            = 300 seconds
. 2018.07.10 16:19:56 -     TIMEOUTclose           = 60 seconds
. 2018.07.10 16:19:56 -     TIMEOUTconnect         = 10 seconds
. 2018.07.10 16:19:56 -     TIMEOUTidle            = 43200 seconds
. 2018.07.10 16:19:56 -     verify                 = none'
. 2018.07.10 16:19:56 - Shell(6) of 'C:\Program Files\AirVPN\curl.exe', 1 args: '--version';
. 2018.07.10 16:19:56 - Shell(6) done in 219 ms, exit: 0, out: 'curl 7.54.1 (x86_64-pc-win32) libcurl/7.54.1 OpenSSL/1.1.0f zlib/1.2.11 WinIDN libssh2/1.8.0 nghttp2/1.23.1
. 2018.07.10 16:19:56 -     Release-Date: 2017-06-14
. 2018.07.10 16:19:56 -     Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smtp smtps telnet tftp
. 2018.07.10 16:19:56 -     Features: AsynchDNS IDN IPv6 Largefile SSPI Kerberos SPNEGO NTLM SSL libz TLS-SRP HTTP2 HTTPS-proxy'
. 2018.07.10 16:19:56 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2018.07.10 16:19:56 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2018.07.10 16:19:56 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2018.07.10 16:19:56 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2018.07.10 16:19:56 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2018.07.10 16:19:56 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
W 2018.07.10 16:19:57 - Recovery. Unexpected crash?
! 2018.07.10 16:19:58 - Deactivation of Network Lock
! 2018.07.10 16:19:58 - Activation of Network Lock - Windows Filtering Platform
. 2018.07.10 16:19:59 - Updating systems & servers data ...
I 2018.07.10 16:19:59 - Ready
. 2018.07.10 16:19:59 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 52.48.66.85 port 80: Network unreachable)
I 2018.07.10 16:20:49 - Checking login ...
! 2018.07.10 16:20:49 - Logged in.
I 2018.07.10 16:21:11 - Session starting.
I 2018.07.10 16:21:11 - Checking authorization ...
! 2018.07.10 16:21:12 - Connecting to Achird (Switzerland, Zurich)
W 2018.07.10 16:21:12 - Unable to compute route for 185.156.175.38: IPv4 Net gateway not available.
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\97b174f040fe3a5fdf7d987ac25463432afb8bd19e3cfa530d27c776ce377c3c.tmp.ssl
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[ui]: Configuration successful
. 2018.07.10 16:21:12 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:21:12 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 16:21:12 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:21:12 - Connection to OpenVPN Management Interface
. 2018.07.10 16:21:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 16:21:12 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:21:12 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:21:12 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:21:12 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:21:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:57884
. 2018.07.10 16:21:12 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 16:21:12 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:57884 [nonblock]
. 2018.07.10 16:21:12 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:57884
. 2018.07.10 16:21:12 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 16:21:12 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:57884
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49690
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: s_connect: connecting 185.156.175.38:443
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[0]: s_connect: connected 185.156.175.38:443
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:49691
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: SNI: sending servername: 185.156.175.38
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: Peer certificate not required
. 2018.07.10 16:21:12 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: Certificate verification disabled
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: Client certificate not requested
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 16:21:12 - SSL > 2018.07.10 16:21:12 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 16:21:12 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:57884, sid=53f7e3b9 c34bad5b
. 2018.07.10 16:21:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 16:21:13 - OpenVPN > VERIFY KU OK
. 2018.07.10 16:21:13 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 16:21:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 16:21:13 - OpenVPN > VERIFY EKU OK
. 2018.07.10 16:21:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 16:21:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 16:21:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:57884
. 2018.07.10 16:21:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 16:21:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.159.1,dhcp-option DNS6 fde6:7a:7d20:9f::1,tun-ipv6,route-gateway 10.4.159.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:9f::1005/64 fde6:7a:7d20:9f::1,ifconfig 10.4.159.7 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 16:21:14 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 16:21:14 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 16:21:14 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 16:21:14 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:21:14 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:21:14 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 16:21:14 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=34 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 16:21:14 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 16:21:14 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 16:21:14 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 16:21:14 - OpenVPN > open_tun
. 2018.07.10 16:21:14 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 16:21:14 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 16:21:14 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.159.0/10.4.159.7/255.255.255.0 [SUCCEEDED]
. 2018.07.10 16:21:14 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.159.7/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.4.159.254, lease-time: 31536000]
. 2018.07.10 16:21:14 - OpenVPN > Successful ARP Flush on interface [5] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 16:21:14 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 16:21:15 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=5 fde6:7a:7d20:9f::1005 store=active
. 2018.07.10 16:21:16 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:9f::1 validate=no
. 2018.07.10 16:21:16 - Shell(7) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 16:21:16 - Shell(7) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:21:16 -     Schnittstellenliste
. 2018.07.10 16:21:16 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:21:16 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:21:16 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:21:16 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:21:16 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:21:16 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:21:16 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:21:16 -     ===========================================================================
. 2018.07.10 16:21:16 -     IPv6-Routentabelle
. 2018.07.10 16:21:16 -     Aktive Routen:
. 2018.07.10 16:21:16 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:21:16 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:21:16 -     5    291 fde6:7a:7d20:9f::/64     fe80::8
. 2018.07.10 16:21:16 -     5    291 fe80::/64                Auf Verbindung
. 2018.07.10 16:21:16 -     34    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:21:16 -     34    281 fe80::1915:6c:aa6f:4f02/128
. 2018.07.10 16:21:16 -     Auf Verbindung
. 2018.07.10 16:21:16 -     5    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:21:16 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:21:16 -     5    291 ff00::/8                 Auf Verbindung
. 2018.07.10 16:21:16 -     34    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:21:16 -     St„ndige Routen:
. 2018.07.10 16:21:16 -     Keine'
. 2018.07.10 16:21:16 - OpenVPN > add_route_ipv6(fde6:7a:7d20:9f::/64 -> fde6:7a:7d20:9f::1005 metric 0) dev Ethernet 2
. 2018.07.10 16:21:16 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:9f::/64 interface=5 fe80::8 store=active
. 2018.07.10 16:21:16 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:21:21 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:21:21 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 16:21:21 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 16:21:21 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 16:21:21 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=5 fe80::8 store=active
. 2018.07.10 16:21:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:21:21 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:21:21 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:21:21 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:9f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:21:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=5 fe80::8 store=active
. 2018.07.10 16:21:21 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 16:21:21 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 16:21:21 - DNS leak protection with packet filtering enabled.
. 2018.07.10 16:21:22 - Shell(8) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 16:21:22 - Shell(8) done in 78 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:21:22 -     Schnittstellenliste
. 2018.07.10 16:21:22 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:21:22 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:21:22 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:21:22 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:21:22 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:21:22 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:21:22 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:21:22 -     ===========================================================================
. 2018.07.10 16:21:22 -     IPv4-Routentabelle
. 2018.07.10 16:21:22 -     Aktive Routen:
. 2018.07.10 16:21:22 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 16:21:22 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:21:22 -     0.0.0.0        128.0.0.0       10.4.159.1       10.4.159.7      3
. 2018.07.10 16:21:22 -     10.4.159.0    255.255.255.0   Auf Verbindung        10.4.159.7    259
. 2018.07.10 16:21:22 -     10.4.159.7  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 16:21:22 -     10.4.159.255  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 16:21:22 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:21:22 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:21:22 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:21:22 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:21:22 -     128.0.0.0        128.0.0.0       10.4.159.1       10.4.159.7      3
. 2018.07.10 16:21:22 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:21:22 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:21:22 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:21:22 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:21:22 -     224.0.0.0        240.0.0.0   Auf Verbindung        10.4.159.7    259
. 2018.07.10 16:21:22 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:21:22 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:21:22 -     255.255.255.255  255.255.255.255   Auf Verbindung        10.4.159.7    259
. 2018.07.10 16:21:22 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:21:22 -     St„ndige Routen:
. 2018.07.10 16:21:22 -     Keine'
. 2018.07.10 16:21:22 - Shell(9) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 16:21:22 - Shell(9) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:21:22 -     IPv6-Routentabelle
. 2018.07.10 16:21:22 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:21:22 -     5    259 ::/3                     fe80::8
. 2018.07.10 16:21:22 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:21:22 -     5    259 2000::/4                 fe80::8
. 2018.07.10 16:21:22 -     5    259 3000::/4                 fe80::8
. 2018.07.10 16:21:22 -     5    259 fc00::/7                 fe80::8
. 2018.07.10 16:21:22 -     5    259 fde6:7a:7d20:9f::/64     fe80::8
. 2018.07.10 16:21:22 -     5    259 fde6:7a:7d20:9f::1005/128
. 2018.07.10 16:21:22 -     Auf Verbindung
. 2018.07.10 16:21:22 -     5    259 fe80::/64                Auf Verbindung
. 2018.07.10 16:21:22 -     34    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:21:22 -     34    281 fe80::1915:6c:aa6f:4f02/128
. 2018.07.10 16:21:22 -     5    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:21:22 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:21:22 -     5    259 ff00::/8                 Auf Verbindung
. 2018.07.10 16:21:22 -     34    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:21:22 - Shell(10) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.4.159.1 register=primary validate=no';
. 2018.07.10 16:21:22 - Shell(10) done in 94 ms, exit: 0
. 2018.07.10 16:21:22 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.4.159.1)
. 2018.07.10 16:21:22 - Shell(11) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:9f::1 register=primary validate=no';
. 2018.07.10 16:21:22 - Shell(11) done in 94 ms, exit: 0
. 2018.07.10 16:21:22 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:9f::1)
. 2018.07.10 16:21:22 - Shell(12) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.35 mask 255.255.255.255 10.4.159.1 if 5';
. 2018.07.10 16:21:22 - Shell(12) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:21:22 - Routes, added a new route, 185.156.175.35 for gateway 10.4.159.1
. 2018.07.10 16:21:22 - Shell(13) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2001:ac8:28:3:4a30:c1b3:8485:40c/128" interface="5" nexthop="fde6:7a:7d20:9f::1"';
. 2018.07.10 16:21:22 - Shell(13) done in 93 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:21:22 - Routes, added a new route, 2001:ac8:28:3:4a30:c1b3:8485:40c for gateway fde6:7a:7d20:9f::1
. 2018.07.10 16:21:22 - Flushing DNS
. 2018.07.10 16:21:22 - Shell(14) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:21:22 - Shell(14) done in 63 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:21:22 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:21:22 - Shell(15) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:21:25 - Shell(15) done in 3062 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:21:25 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 16:21:26 - Checking route IPv4
I 2018.07.10 16:21:26 - Checking route IPv6
I 2018.07.10 16:21:29 - Checking DNS
! 2018.07.10 16:21:30 - Connected.
. 2018.07.10 16:21:30 - OpenVPN > Initialization Sequence Completed
. 2018.07.10 16:22:12 - SSL > 2018.07.10 16:22:12 LOG6[cron]: Executing cron jobs
. 2018.07.10 16:22:12 - SSL > 2018.07.10 16:22:12 LOG6[cron]: Cron jobs completed in 0 seconds
! 2018.07.10 16:25:56 - Disconnecting
. 2018.07.10 16:25:56 - Shell(16) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.35 mask 255.255.255.255 10.4.159.1 if 5';
. 2018.07.10 16:25:56 - Shell(16) done in 78 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:25:56 - Routes, removed a route previously added, 185.156.175.35 for gateway 10.4.159.1
. 2018.07.10 16:25:56 - Shell(17) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2001:ac8:28:3:4a30:c1b3:8485:40c/128" interface="5" nexthop="fde6:7a:7d20:9f::1"';
. 2018.07.10 16:25:56 - Shell(17) done in 110 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:25:56 - Routes, removed a route previously added, 2001:ac8:28:3:4a30:c1b3:8485:40c for gateway fde6:7a:7d20:9f::1
. 2018.07.10 16:25:56 - Sending management termination signal
. 2018.07.10 16:25:56 - Management - Send 'signal SIGTERM'
. 2018.07.10 16:25:56 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 16:25:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:25:56 - SSL > 2018.07.10 16:25:56 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 16:25:56 - SSL > 2018.07.10 16:25:56 LOG5[0]: Connection reset: 496404 byte(s) sent to TLS, 4321677 byte(s) sent to socket
. 2018.07.10 16:25:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 16:25:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 16:25:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.159.1
. 2018.07.10 16:25:56 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 16:25:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=5 fe80::8 store=active
. 2018.07.10 16:25:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:25:56 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 16:25:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:25:56 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 16:25:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:25:57 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 16:25:57 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=5 fe80::8 store=active
. 2018.07.10 16:25:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:25:57 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 16:25:57 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:9f::/64)
. 2018.07.10 16:25:57 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:9f::/64 interface=5 fe80::8 store=active
. 2018.07.10 16:25:57 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:9f::1005 store=active
. 2018.07.10 16:25:57 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 16:25:57 - OpenVPN > TAP: DHCP address released
. 2018.07.10 16:25:57 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 16:26:06 - Sending soft termination signal
. 2018.07.10 16:26:06 - Connection terminated.
. 2018.07.10 16:26:06 - Shell(18) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:26:06 - Shell(18) done in 94 ms, exit: 0
. 2018.07.10 16:26:06 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:26:06 - Shell(19) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:26:06 - Shell(19) done in 93 ms, exit: 0
. 2018.07.10 16:26:06 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:26:06 - DNS leak protection with packet filtering disabled.
. 2018.07.10 16:26:06 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 16:26:06 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
. 2018.07.10 16:26:06 - Flushing DNS
. 2018.07.10 16:26:06 - Shell(20) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:26:06 - Shell(20) done in 47 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:26:06 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:26:06 - Shell(21) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:26:10 - Shell(21) done in 3062 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:26:10 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
! 2018.07.10 16:26:10 - Session terminated.
I 2018.07.10 16:27:26 - Session starting.
I 2018.07.10 16:27:27 - Checking authorization ...
! 2018.07.10 16:27:27 - Connecting to Baiten (Switzerland, Zurich)
W 2018.07.10 16:27:27 - Unable to compute route for 185.156.175.54: IPv4 Net gateway not available.
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\af7be65e766d65fb414364f455cd6ef7f1925ffcfd8beb4ca6b97c24eca8c73b.tmp.ssl
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 16:27:27 - SSL > 2018.07.10 16:27:27 LOG5[ui]: Configuration successful
. 2018.07.10 16:27:28 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:27:28 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 16:27:28 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:27:28 - Connection to OpenVPN Management Interface
. 2018.07.10 16:27:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 16:27:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:27:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:27:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:27:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:27:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:64630
. 2018.07.10 16:27:28 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 16:27:28 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:64630 [nonblock]
. 2018.07.10 16:27:28 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:64630
. 2018.07.10 16:27:28 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 16:27:28 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:64630
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:27 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49916
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:27 LOG6[0]: s_connect: connecting 185.156.175.54:443
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:27 LOG5[0]: s_connect: connected 185.156.175.54:443
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:27 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:49917
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:27 LOG6[0]: SNI: sending servername: 185.156.175.54
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:27 LOG6[0]: Peer certificate not required
. 2018.07.10 16:27:28 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:28 LOG6[0]: Certificate verification disabled
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:28 LOG6[0]: Client certificate not requested
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:28 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 16:27:28 - SSL > 2018.07.10 16:27:28 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 16:27:28 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:64630, sid=72a3b683 3d8af221
. 2018.07.10 16:27:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 16:27:28 - OpenVPN > VERIFY KU OK
. 2018.07.10 16:27:28 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 16:27:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 16:27:28 - OpenVPN > VERIFY EKU OK
. 2018.07.10 16:27:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 16:27:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 16:27:28 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:64630
. 2018.07.10 16:27:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 16:27:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.11.95.1,dhcp-option DNS6 fde6:7a:7d20:75f::1,tun-ipv6,route-gateway 10.11.95.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:75f::1004/64 fde6:7a:7d20:75f::1,ifconfig 10.11.95.6 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 16:27:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 16:27:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 16:27:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 16:27:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:27:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:27:29 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 16:27:29 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=34 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 16:27:29 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 16:27:29 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 16:27:29 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 16:27:29 - OpenVPN > open_tun
. 2018.07.10 16:27:29 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 16:27:29 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 16:27:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.11.95.0/10.11.95.6/255.255.255.0 [SUCCEEDED]
. 2018.07.10 16:27:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.11.95.6/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.11.95.254, lease-time: 31536000]
. 2018.07.10 16:27:29 - OpenVPN > Successful ARP Flush on interface [5] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 16:27:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 16:27:30 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=5 fde6:7a:7d20:75f::1004 store=active
. 2018.07.10 16:27:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:75f::1 validate=no
. 2018.07.10 16:27:31 - Shell(22) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 16:27:32 - Shell(22) done in 63 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:27:32 -     Schnittstellenliste
. 2018.07.10 16:27:32 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:27:32 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:27:32 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:27:32 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:27:32 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:27:32 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:27:32 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:27:32 -     ===========================================================================
. 2018.07.10 16:27:32 -     IPv6-Routentabelle
. 2018.07.10 16:27:32 -     Aktive Routen:
. 2018.07.10 16:27:32 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:27:32 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:27:32 -     5    291 fe80::/64                Auf Verbindung
. 2018.07.10 16:27:32 -     34    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:27:32 -     34    281 fe80::1915:6c:aa6f:4f02/128
. 2018.07.10 16:27:32 -     Auf Verbindung
. 2018.07.10 16:27:32 -     5    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:27:32 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:27:32 -     5    291 ff00::/8                 Auf Verbindung
. 2018.07.10 16:27:32 -     34    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:27:32 -     St„ndige Routen:
. 2018.07.10 16:27:32 -     Keine'
. 2018.07.10 16:27:32 - OpenVPN > add_route_ipv6(fde6:7a:7d20:75f::/64 -> fde6:7a:7d20:75f::1004 metric 0) dev Ethernet 2
. 2018.07.10 16:27:32 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:75f::/64 interface=5 fe80::8 store=active
. 2018.07.10 16:27:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:27:37 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 16:27:37 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:27:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 16:27:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 16:27:37 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:27:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 16:27:37 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:27:37 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:27:37 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=5 fe80::8 store=active
. 2018.07.10 16:27:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:27:38 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:27:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:27:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:27:38 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:27:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:27:38 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:75f::1 metric -1) dev Ethernet 2
. 2018.07.10 16:27:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=5 fe80::8 store=active
. 2018.07.10 16:27:38 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 16:27:38 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 16:27:38 - DNS leak protection with packet filtering enabled.
. 2018.07.10 16:27:38 - Shell(23) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 16:27:38 - Shell(23) done in 94 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:27:38 -     Schnittstellenliste
. 2018.07.10 16:27:38 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:27:38 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:27:38 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:27:38 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:27:38 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:27:38 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:27:38 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:27:38 -     ===========================================================================
. 2018.07.10 16:27:38 -     IPv4-Routentabelle
. 2018.07.10 16:27:38 -     Aktive Routen:
. 2018.07.10 16:27:38 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 16:27:38 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:27:38 -     0.0.0.0        128.0.0.0       10.11.95.1       10.11.95.6      3
. 2018.07.10 16:27:38 -     10.11.95.0    255.255.255.0   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:27:38 -     10.11.95.6  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:27:38 -     10.11.95.255  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:27:38 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:27:38 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:27:38 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:27:38 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:27:38 -     128.0.0.0        128.0.0.0       10.11.95.1       10.11.95.6      3
. 2018.07.10 16:27:38 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:27:38 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:27:38 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:27:38 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:27:38 -     224.0.0.0        240.0.0.0   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:27:38 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:27:38 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:27:38 -     255.255.255.255  255.255.255.255   Auf Verbindung        10.11.95.6    259
. 2018.07.10 16:27:38 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:27:38 -     St„ndige Routen:
. 2018.07.10 16:27:38 -     Keine'
. 2018.07.10 16:27:38 - Shell(24) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 16:27:38 - Shell(24) done in 62 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:27:38 -     IPv6-Routentabelle
. 2018.07.10 16:27:38 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:27:38 -     5    259 ::/3                     fe80::8
. 2018.07.10 16:27:38 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:27:38 -     5    259 2000::/4                 fe80::8
. 2018.07.10 16:27:38 -     5    259 3000::/4                 fe80::8
. 2018.07.10 16:27:38 -     5    259 fc00::/7                 fe80::8
. 2018.07.10 16:27:38 -     5    259 fde6:7a:7d20:75f::/64    fe80::8
. 2018.07.10 16:27:38 -     5    259 fde6:7a:7d20:75f::1004/128
. 2018.07.10 16:27:38 -     Auf Verbindung
. 2018.07.10 16:27:38 -     5    259 fe80::/64                Auf Verbindung
. 2018.07.10 16:27:38 -     34    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:27:38 -     34    281 fe80::1915:6c:aa6f:4f02/128
. 2018.07.10 16:27:38 -     5    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:27:38 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:27:38 -     5    259 ff00::/8                 Auf Verbindung
. 2018.07.10 16:27:38 -     34    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:27:38 - Shell(25) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.11.95.1 register=primary validate=no';
. 2018.07.10 16:27:38 - Shell(25) done in 109 ms, exit: 0
. 2018.07.10 16:27:38 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.11.95.1)
. 2018.07.10 16:27:38 - Shell(26) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:75f::1 register=primary validate=no';
. 2018.07.10 16:27:38 - Shell(26) done in 93 ms, exit: 0
. 2018.07.10 16:27:38 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:75f::1)
. 2018.07.10 16:27:38 - Shell(27) of 'cmd.exe', 2 args: '/c';'route add 185.156.175.51 mask 255.255.255.255 10.11.95.1 if 5';
. 2018.07.10 16:27:38 - Shell(27) done in 32 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:27:38 - Routes, added a new route, 185.156.175.51 for gateway 10.11.95.1
. 2018.07.10 16:27:39 - Shell(28) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2001:ac8:28:5:6fae:73b:958e:2b90/128" interface="5" nexthop="fde6:7a:7d20:75f::1"';
. 2018.07.10 16:27:39 - Shell(28) done in 94 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:27:39 - Routes, added a new route, 2001:ac8:28:5:6fae:73b:958e:2b90 for gateway fde6:7a:7d20:75f::1
. 2018.07.10 16:27:39 - Flushing DNS
. 2018.07.10 16:27:39 - Shell(29) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:27:39 - Shell(29) done in 47 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:27:39 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:27:39 - Shell(30) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:27:42 - Shell(30) done in 3047 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:27:42 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 16:27:42 - Checking route IPv4
I 2018.07.10 16:27:42 - Checking route IPv6
I 2018.07.10 16:27:46 - Checking DNS
! 2018.07.10 16:27:46 - Connected.
. 2018.07.10 16:27:46 - OpenVPN > Initialization Sequence Completed
. 2018.07.10 16:28:27 - SSL > 2018.07.10 16:28:27 LOG6[cron]: Executing cron jobs
. 2018.07.10 16:28:27 - SSL > 2018.07.10 16:28:27 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 16:30:55 - Updating systems & servers data ...
. 2018.07.10 16:30:56 - Systems & servers data update completed
! 2018.07.10 16:38:25 - Disconnecting
. 2018.07.10 16:38:25 - Shell(31) of 'cmd.exe', 2 args: '/c';'route delete 185.156.175.51 mask 255.255.255.255 10.11.95.1 if 5';
. 2018.07.10 16:38:25 - Shell(31) done in 94 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:38:25 - Routes, removed a route previously added, 185.156.175.51 for gateway 10.11.95.1
. 2018.07.10 16:38:25 - Shell(32) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2001:ac8:28:5:6fae:73b:958e:2b90/128" interface="5" nexthop="fde6:7a:7d20:75f::1"';
. 2018.07.10 16:38:25 - Shell(32) done in 125 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:38:25 - Routes, removed a route previously added, 2001:ac8:28:5:6fae:73b:958e:2b90 for gateway fde6:7a:7d20:75f::1
. 2018.07.10 16:38:25 - Sending management termination signal
. 2018.07.10 16:38:25 - Management - Send 'signal SIGTERM'
. 2018.07.10 16:38:25 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 16:38:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:38:25 - SSL > 2018.07.10 16:38:25 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 16:38:25 - SSL > 2018.07.10 16:38:25 LOG5[0]: Connection reset: 908718 byte(s) sent to TLS, 9866839 byte(s) sent to socket
. 2018.07.10 16:38:25 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 16:38:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:38:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.11.95.1
. 2018.07.10 16:38:25 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 16:38:25 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=5 fe80::8 store=active
. 2018.07.10 16:38:25 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:38:26 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 16:38:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:38:26 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:38:26 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 16:38:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:38:26 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 16:38:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=5 fe80::8 store=active
. 2018.07.10 16:38:26 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 16:38:26 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:75f::/64)
. 2018.07.10 16:38:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:75f::/64 interface=5 fe80::8 store=active
. 2018.07.10 16:38:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:75f::1004 store=active
. 2018.07.10 16:38:26 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 16:38:26 - OpenVPN > TAP: DHCP address released
. 2018.07.10 16:38:26 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 16:38:35 - Sending soft termination signal
. 2018.07.10 16:38:35 - Connection terminated.
. 2018.07.10 16:38:35 - Shell(33) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:38:35 - Shell(33) done in 109 ms, exit: 0
. 2018.07.10 16:38:35 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:38:35 - Shell(34) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=dhcp register=primary validate=no';
. 2018.07.10 16:38:35 - Shell(34) done in 93 ms, exit: 0
. 2018.07.10 16:38:35 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 16:38:35 - DNS leak protection with packet filtering disabled.
. 2018.07.10 16:38:35 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 16:38:35 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
. 2018.07.10 16:38:35 - Flushing DNS
. 2018.07.10 16:38:35 - Shell(35) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:38:35 - Shell(35) done in 47 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:38:35 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:38:35 - Shell(36) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:38:39 - Shell(36) done in 3062 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:38:39 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
! 2018.07.10 16:38:39 - Session terminated.
I 2018.07.10 16:39:01 - Session starting.
I 2018.07.10 16:39:01 - Checking authorization ...
! 2018.07.10 16:39:02 - Connecting to Orion (Netherlands, Alblasserdam)
W 2018.07.10 16:39:02 - Unable to compute route for 213.152.161.242: IPv4 Net gateway not available.
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\c8848d58315a23de0a4f302da672230189f1feb73de3d98d6dc4f521ac5e6311.tmp.ssl
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[ui]: Configuration successful
. 2018.07.10 16:39:02 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:39:02 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 16:39:02 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:39:02 - Connection to OpenVPN Management Interface
. 2018.07.10 16:39:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 16:39:02 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:39:02 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:39:02 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 16:39:02 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 16:39:02 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:45868
. 2018.07.10 16:39:02 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 16:39:02 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:45868 [nonblock]
. 2018.07.10 16:39:02 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:45868
. 2018.07.10 16:39:02 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 16:39:02 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:45868
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50031
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: s_connect: connecting 213.152.161.242:443
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[0]: s_connect: connected 213.152.161.242:443
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50032
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: SNI: sending servername: 213.152.161.242
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: Peer certificate not required
. 2018.07.10 16:39:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: Certificate verification disabled
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: Client certificate not requested
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 16:39:02 - SSL > 2018.07.10 16:39:02 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 16:39:02 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:45868, sid=2c6cc737 bda42c29
. 2018.07.10 16:39:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 16:39:02 - OpenVPN > VERIFY KU OK
. 2018.07.10 16:39:02 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 16:39:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 16:39:02 - OpenVPN > VERIFY EKU OK
. 2018.07.10 16:39:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org
. 2018.07.10 16:39:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 16:39:03 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]127.0.0.1:45868
. 2018.07.10 16:39:04 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 16:39:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.255.1,dhcp-option DNS6 fde6:7a:7d20:15ff::1,tun-ipv6,route-gateway 10.25.255.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15ff::1004/64 fde6:7a:7d20:15ff::1,ifconfig 10.25.255.6 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 16:39:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 16:39:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 16:39:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 16:39:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:39:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:39:04 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 16:39:04 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=34 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 16:39:04 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 16:39:04 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 16:39:04 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 16:39:04 - OpenVPN > open_tun
. 2018.07.10 16:39:04 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 16:39:04 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 16:39:04 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.25.255.0/10.25.255.6/255.255.255.0 [SUCCEEDED]
. 2018.07.10 16:39:04 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.25.255.6/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.25.255.254, lease-time: 31536000]
. 2018.07.10 16:39:04 - OpenVPN > Successful ARP Flush on interface [5] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 16:39:04 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 16:39:05 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=5 fde6:7a:7d20:15ff::1004 store=active
. 2018.07.10 16:39:06 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:15ff::1 validate=no
. 2018.07.10 16:39:06 - Shell(37) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.07.10 16:39:06 - Shell(37) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:39:06 -     Schnittstellenliste
. 2018.07.10 16:39:06 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:39:06 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:39:06 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:39:06 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:39:06 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:39:06 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:39:06 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:39:06 -     ===========================================================================
. 2018.07.10 16:39:06 -     IPv6-Routentabelle
. 2018.07.10 16:39:06 -     Aktive Routen:
. 2018.07.10 16:39:06 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:39:06 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:39:06 -     5    291 fde6:7a:7d20:15ff::/64   fe80::8
. 2018.07.10 16:39:06 -     5    291 fe80::/64                Auf Verbindung
. 2018.07.10 16:39:06 -     34    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:39:06 -     34    281 fe80::1915:6c:aa6f:4f02/128
. 2018.07.10 16:39:06 -     Auf Verbindung
. 2018.07.10 16:39:06 -     5    291 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:39:06 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:39:06 -     5    291 ff00::/8                 Auf Verbindung
. 2018.07.10 16:39:06 -     34    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:39:06 -     St„ndige Routen:
. 2018.07.10 16:39:06 -     Keine'
. 2018.07.10 16:39:06 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15ff::/64 -> fde6:7a:7d20:15ff::1004 metric 0) dev Ethernet 2
. 2018.07.10 16:39:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15ff::/64 interface=5 fe80::8 store=active
. 2018.07.10 16:39:06 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:39:11 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 16:39:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 16:39:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.255.1
. 2018.07.10 16:39:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.255.1
. 2018.07.10 16:39:11 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:15ff::1 metric -1) dev Ethernet 2
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=5 fe80::8 store=active
. 2018.07.10 16:39:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:39:11 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:15ff::1 metric -1) dev Ethernet 2
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:39:11 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:15ff::1 metric -1) dev Ethernet 2
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=5 fe80::8 store=active
. 2018.07.10 16:39:11 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:15ff::1 metric -1) dev Ethernet 2
. 2018.07.10 16:39:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=5 fe80::8 store=active
. 2018.07.10 16:39:12 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 16:39:12 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 16:39:12 - DNS leak protection with packet filtering enabled.
. 2018.07.10 16:39:12 - Shell(38) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.07.10 16:39:12 - Shell(38) done in 94 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:39:12 -     Schnittstellenliste
. 2018.07.10 16:39:12 -     5...00 ff 58 f2 6a a1 ......TAP-Windows Adapter V9
. 2018.07.10 16:39:12 -     34...f4 4d 30 61 5b 8c ......Intel(R) Ethernet Connection I219-V
. 2018.07.10 16:39:12 -     21...00 c2 c6 ce ca 5c ......Intel(R) Dual Band Wireless-AC 8260
. 2018.07.10 16:39:12 -     38...00 c2 c6 ce ca 5d ......Microsoft Wi-Fi Direct Virtual Adapter #3
. 2018.07.10 16:39:12 -     43...02 c2 c6 ce ca 5c ......Microsoft Wi-Fi Direct Virtual Adapter #4
. 2018.07.10 16:39:12 -     19...00 c2 c6 ce ca 60 ......Bluetooth Device (Personal Area Network)
. 2018.07.10 16:39:12 -     1...........................Software Loopback Interface 1
. 2018.07.10 16:39:12 -     ===========================================================================
. 2018.07.10 16:39:12 -     IPv4-Routentabelle
. 2018.07.10 16:39:12 -     Aktive Routen:
. 2018.07.10 16:39:12 -     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
. 2018.07.10 16:39:12 -     0.0.0.0          0.0.0.0      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:39:12 -     0.0.0.0        128.0.0.0      10.25.255.1      10.25.255.6      3
. 2018.07.10 16:39:12 -     10.25.255.0    255.255.255.0   Auf Verbindung       10.25.255.6    259
. 2018.07.10 16:39:12 -     10.25.255.6  255.255.255.255   Auf Verbindung       10.25.255.6    259
. 2018.07.10 16:39:12 -     10.25.255.255  255.255.255.255   Auf Verbindung       10.25.255.6    259
. 2018.07.10 16:39:12 -     127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:39:12 -     127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:39:12 -     127.0.0.1  255.255.255.255      192.168.0.1    192.168.0.101     25
. 2018.07.10 16:39:12 -     127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:39:12 -     128.0.0.0        128.0.0.0      10.25.255.1      10.25.255.6      3
. 2018.07.10 16:39:12 -     192.168.0.0    255.255.255.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:39:12 -     192.168.0.101  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:39:12 -     192.168.0.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:39:12 -     224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:39:12 -     224.0.0.0        240.0.0.0   Auf Verbindung       10.25.255.6    259
. 2018.07.10 16:39:12 -     224.0.0.0        240.0.0.0   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:39:12 -     255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
. 2018.07.10 16:39:12 -     255.255.255.255  255.255.255.255   Auf Verbindung       10.25.255.6    259
. 2018.07.10 16:39:12 -     255.255.255.255  255.255.255.255   Auf Verbindung     192.168.0.101    281
. 2018.07.10 16:39:12 -     St„ndige Routen:
. 2018.07.10 16:39:12 -     Keine'
. 2018.07.10 16:39:12 - Shell(39) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.07.10 16:39:12 - Shell(39) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.07.10 16:39:12 -     IPv6-Routentabelle
. 2018.07.10 16:39:12 -     If Metrik Netzwerkziel             Gateway
. 2018.07.10 16:39:12 -     5    259 ::/3                     fe80::8
. 2018.07.10 16:39:12 -     1    331 ::1/128                  Auf Verbindung
. 2018.07.10 16:39:12 -     5    259 2000::/4                 fe80::8
. 2018.07.10 16:39:12 -     5    259 3000::/4                 fe80::8
. 2018.07.10 16:39:12 -     5    259 fc00::/7                 fe80::8
. 2018.07.10 16:39:12 -     5    259 fde6:7a:7d20:15ff::/64   fe80::8
. 2018.07.10 16:39:12 -     5    259 fde6:7a:7d20:15ff::1004/128
. 2018.07.10 16:39:12 -     Auf Verbindung
. 2018.07.10 16:39:12 -     5    259 fe80::/64                Auf Verbindung
. 2018.07.10 16:39:12 -     34    281 fe80::/64                Auf Verbindung
. 2018.07.10 16:39:12 -     34    281 fe80::1915:6c:aa6f:4f02/128
. 2018.07.10 16:39:12 -     5    259 fe80::dd5e:1cca:59e6:b50c/128
. 2018.07.10 16:39:12 -     1    331 ff00::/8                 Auf Verbindung
. 2018.07.10 16:39:12 -     5    259 ff00::/8                 Auf Verbindung
. 2018.07.10 16:39:12 -     34    281 ff00::/8                 Auf Verbindung
. 2018.07.10 16:39:12 - Shell(40) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Ethernet 2" source=static address=10.25.255.1 register=primary validate=no';
. 2018.07.10 16:39:12 - Shell(40) done in 110 ms, exit: 0
. 2018.07.10 16:39:12 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.25.255.1)
. 2018.07.10 16:39:12 - Shell(41) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Ethernet 2" source=static address=fde6:7a:7d20:15ff::1 register=primary validate=no';
. 2018.07.10 16:39:12 - Shell(41) done in 109 ms, exit: 0
. 2018.07.10 16:39:12 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:15ff::1)
. 2018.07.10 16:39:12 - Shell(42) of 'cmd.exe', 2 args: '/c';'route add 213.152.161.239 mask 255.255.255.255 10.25.255.1 if 5';
. 2018.07.10 16:39:12 - Shell(42) done in 47 ms, exit: 0, out: 'OK!'
. 2018.07.10 16:39:12 - Routes, added a new route, 213.152.161.239 for gateway 10.25.255.1
. 2018.07.10 16:39:12 - Shell(43) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2a00:1678:2470:48:f42c:a766:986e:eab1/128" interface="5" nexthop="fde6:7a:7d20:15ff::1"';
. 2018.07.10 16:39:12 - Shell(43) done in 110 ms, exit: 0, out: 'OK.'
. 2018.07.10 16:39:12 - Routes, added a new route, 2a00:1678:2470:48:f42c:a766:986e:eab1 for gateway fde6:7a:7d20:15ff::1
. 2018.07.10 16:39:12 - Flushing DNS
. 2018.07.10 16:39:12 - Shell(44) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.07.10 16:39:13 - Shell(44) done in 62 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:39:13 -     Der DNS-Aufl”sungscache wurde geleert.'
. 2018.07.10 16:39:13 - Shell(45) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.07.10 16:39:16 - Shell(45) done in 3063 ms, exit: 0, out: 'Windows-IP-Konfiguration
. 2018.07.10 16:39:16 -     Die Registrierung der DNS-Ressourceneintr„ge fr alle Adapter dieses Computer wurde initialisiert. Fehler werden in der Ereignisanzeige in 15 Minuten aufgefhrt.'
I 2018.07.10 16:39:16 - Checking route IPv4
I 2018.07.10 16:39:16 - Checking route IPv6
I 2018.07.10 16:39:19 - Checking DNS
! 2018.07.10 16:39:20 - Connected.
. 2018.07.10 16:39:20 - OpenVPN > Initialization Sequence Completed
. 2018.07.10 16:40:02 - SSL > 2018.07.10 16:40:02 LOG6[cron]: Executing cron jobs
. 2018.07.10 16:40:02 - SSL > 2018.07.10 16:40:02 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 16:41:53 - Updating systems & servers data ...
. 2018.07.10 16:41:54 - Systems & servers data update completed
. 2018.07.10 16:52:01 - Updating systems & servers data ...
. 2018.07.10 16:52:02 - Systems & servers data update completed
. 2018.07.10 17:02:37 - Updating systems & servers data ...
. 2018.07.10 17:02:38 - Systems & servers data update completed
. 2018.07.10 17:13:15 - Updating systems & servers data ...
. 2018.07.10 17:13:16 - Systems & servers data update completed
and here's an example of IPv6 problems. and here is an example of IPv6 problems, the problem I had with most servers!
. 2018.07.10 15:10:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:10:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:10:06 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.159.1
. 2018.07.10 15:10:06 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1a9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:10:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:10:06 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:10:06 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1a9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:10:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:10:06 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1a9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:10:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:10:07 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1a9f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:10:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:10:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:10:07 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:10:07 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:10:07 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:10:07 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.30.159.1)
. 2018.07.10 15:10:07 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1a9f::1)
. 2018.07.10 15:10:07 - Routes, added a new route, 213.152.161.74 for gateway 10.30.159.1
. 2018.07.10 15:10:07 - Routes, added a new route, 2a00:1678:2470:13:df5e:761a:e1d:cd0a for gateway fde6:7a:7d20:1a9f::1
. 2018.07.10 15:10:07 - Flushing DNS
I 2018.07.10 15:10:11 - Checking route IPv4
I 2018.07.10 15:10:11 - Checking route IPv6
. 2018.07.10 15:10:31 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:10:31 - Checking route (2° try)
. 2018.07.10 15:10:52 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 15:10:52 - Checking route (3° try)
. 2018.07.10 15:11:14 - curl: (28) Connection timed out after 20016 milliseconds
E 2018.07.10 15:11:14 - Checking route IPv6 failed.
. 2018.07.10 15:11:14 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:11:14 - Disconnecting
. 2018.07.10 15:11:14 - Routes, removed a route previously added, 213.152.161.77 for gateway 192.168.0.1
. 2018.07.10 15:11:14 - Routes, removed a route previously added, 213.152.161.74 for gateway 10.30.159.1
. 2018.07.10 15:11:14 - Routes, removed a route previously added, 2a00:1678:2470:13:df5e:761a:e1d:cd0a for gateway fde6:7a:7d20:1a9f::1
. 2018.07.10 15:11:14 - SSL > 2018.07.10 15:10:57 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:11:14 - SSL > 2018.07.10 15:10:57 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:11:14 - Sending management termination signal
. 2018.07.10 15:11:14 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:11:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:11:15 - SSL > 2018.07.10 15:11:14 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:11:15 - SSL > 2018.07.10 15:11:14 LOG5[0]: Connection reset: 7283 byte(s) sent to TLS, 14802 byte(s) sent to socket
. 2018.07.10 15:11:15 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.159.1
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.159.1
. 2018.07.10 15:11:15 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:11:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:11:15 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:11:15 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:11:15 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:11:15 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:11:15 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1a9f::/64)
. 2018.07.10 15:11:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1a9f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:11:15 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1a9f::1007 store=active
. 2018.07.10 15:11:15 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:11:15 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:11:15 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:11:24 - Sending soft termination signal
. 2018.07.10 15:11:24 - Connection terminated.
. 2018.07.10 15:11:24 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:11:24 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:11:24 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:11:24 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:11:24 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:11:27 - Checking authorization ...
! 2018.07.10 15:11:28 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2018.07.10 15:11:28 - Routes, added a new route, 109.202.107.8 for gateway 192.168.0.1
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\d84dc13bca5edd520ed2032bc0a4a342bce98b72f0d424e03dbc3560e65ad347.tmp.ssl
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[ui]: Configuration successful
. 2018.07.10 15:11:28 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:11:28 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:11:28 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:11:28 - Connection to OpenVPN Management Interface
. 2018.07.10 15:11:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:11:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:11:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:11:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:11:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:11:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:55988
. 2018.07.10 15:11:28 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:11:28 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:55988 [nonblock]
. 2018.07.10 15:11:28 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:55988
. 2018.07.10 15:11:28 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:11:28 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:55988
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49736
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG6[0]: s_connect: connecting 109.202.107.8:443
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[0]: s_connect: connected 109.202.107.8:443
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:49737
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG6[0]: SNI: sending servername: 109.202.107.8
. 2018.07.10 15:11:28 - SSL > 2018.07.10 15:11:28 LOG6[0]: Peer certificate not required
. 2018.07.10 15:11:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:11:29 - SSL > 2018.07.10 15:11:28 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:11:29 - SSL > 2018.07.10 15:11:28 LOG6[0]: Client certificate not requested
. 2018.07.10 15:11:29 - SSL > 2018.07.10 15:11:28 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:11:29 - SSL > 2018.07.10 15:11:28 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:11:29 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:55988, sid=de3a4b3b f450d678
. 2018.07.10 15:11:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:11:29 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:11:29 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:11:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:11:29 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:11:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:11:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:11:29 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:55988
. 2018.07.10 15:11:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:11:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.7.95.1,dhcp-option DNS6 fde6:7a:7d20:35f::1,tun-ipv6,route-gateway 10.7.95.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:35f::1000/64 fde6:7a:7d20:35f::1,ifconfig 10.7.95.2 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:11:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:11:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:11:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:11:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:11:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:11:30 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:11:30 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:11:30 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:11:30 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:11:30 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:11:30 - OpenVPN > open_tun
. 2018.07.10 15:11:30 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:11:30 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:11:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.7.95.0/10.7.95.2/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:11:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.7.95.2/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.7.95.254, lease-time: 31536000]
. 2018.07.10 15:11:30 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:11:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:11:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:35f::1000 store=active
. 2018.07.10 15:11:32 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:35f::1 validate=no
. 2018.07.10 15:11:32 - OpenVPN > add_route_ipv6(fde6:7a:7d20:35f::/64 -> fde6:7a:7d20:35f::1000 metric 0) dev Ethernet 2
. 2018.07.10 15:11:32 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:35f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:11:32 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:11:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:11:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:11:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.7.95.1
. 2018.07.10 15:11:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.7.95.1
. 2018.07.10 15:11:38 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:35f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:11:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:11:38 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:35f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:11:38 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:35f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:11:38 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:35f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:11:38 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:11:38 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:11:38 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:11:38 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:11:38 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.7.95.1)
. 2018.07.10 15:11:38 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:35f::1)
. 2018.07.10 15:11:38 - Routes, added a new route, 109.202.107.5 for gateway 10.7.95.1
. 2018.07.10 15:11:39 - Routes, added a new route, 2a00:1678:2470:23:eaab:e065:ac57:b54e for gateway fde6:7a:7d20:35f::1
. 2018.07.10 15:11:39 - Flushing DNS
I 2018.07.10 15:11:42 - Checking route IPv4
I 2018.07.10 15:11:42 - Checking route IPv6
. 2018.07.10 15:12:02 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:12:02 - Checking route (2° try)
. 2018.07.10 15:12:23 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 15:12:23 - Checking route (3° try)
. 2018.07.10 15:12:45 - curl: (28) Connection timed out after 20016 milliseconds
E 2018.07.10 15:12:45 - Checking route IPv6 failed.
. 2018.07.10 15:12:45 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:12:45 - Disconnecting
. 2018.07.10 15:12:45 - Routes, removed a route previously added, 109.202.107.8 for gateway 192.168.0.1
. 2018.07.10 15:12:45 - Routes, removed a route previously added, 109.202.107.5 for gateway 10.7.95.1
. 2018.07.10 15:12:46 - Routes, removed a route previously added, 2a00:1678:2470:23:eaab:e065:ac57:b54e for gateway fde6:7a:7d20:35f::1
. 2018.07.10 15:12:46 - SSL > 2018.07.10 15:12:28 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:12:46 - SSL > 2018.07.10 15:12:28 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:12:46 - Sending management termination signal
. 2018.07.10 15:12:46 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:12:46 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:12:46 - SSL > 2018.07.10 15:12:46 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:12:46 - SSL > 2018.07.10 15:12:46 LOG5[0]: Connection reset: 8726 byte(s) sent to TLS, 16754 byte(s) sent to socket
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:12:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.7.95.1
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.7.95.1
. 2018.07.10 15:12:46 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:12:46 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:12:46 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:12:46 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:12:46 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:12:46 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:12:46 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:35f::/64)
. 2018.07.10 15:12:46 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:35f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:12:46 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:35f::1000 store=active
. 2018.07.10 15:12:46 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:12:46 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:12:46 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:12:55 - Sending soft termination signal
. 2018.07.10 15:12:55 - Connection terminated.
. 2018.07.10 15:12:55 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:12:55 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:12:55 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:12:55 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:12:55 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:12:58 - Checking authorization ...
! 2018.07.10 15:12:59 - Connecting to Alcyone (Netherlands, Alblasserdam)
. 2018.07.10 15:12:59 - Routes, added a new route, 213.152.161.120 for gateway 192.168.0.1
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\fb4ba5409acd65fb3a3e7ecaf3dce0faaa620c850cb6bb3a9920812c0fe62836.tmp.ssl
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[ui]: Configuration successful
. 2018.07.10 15:12:59 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:12:59 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:12:59 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:12:59 - Connection to OpenVPN Management Interface
. 2018.07.10 15:12:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:12:59 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:12:59 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:12:59 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:12:59 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:12:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:14900
. 2018.07.10 15:12:59 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:12:59 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:14900 [nonblock]
. 2018.07.10 15:12:59 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:14900
. 2018.07.10 15:12:59 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:12:59 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:14900
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49793
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: s_connect: connecting 213.152.161.120:443
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[0]: s_connect: connected 213.152.161.120:443
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:49794
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: SNI: sending servername: 213.152.161.120
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: Peer certificate not required
. 2018.07.10 15:12:59 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: Client certificate not requested
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:12:59 - SSL > 2018.07.10 15:12:59 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:12:59 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:14900, sid=6c853b04 d28a13a6
. 2018.07.10 15:13:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:13:00 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:13:00 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:13:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:13:00 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:13:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:13:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:13:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:14900
. 2018.07.10 15:13:01 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:13:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.5.223.1,dhcp-option DNS6 fde6:7a:7d20:1df::1,tun-ipv6,route-gateway 10.5.223.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1df::100a/64 fde6:7a:7d20:1df::1,ifconfig 10.5.223.12 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:13:01 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:13:01 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:13:01 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:13:01 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:13:01 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:13:01 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:13:01 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:13:01 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:13:01 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:13:01 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:13:01 - OpenVPN > open_tun
. 2018.07.10 15:13:01 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:13:01 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:13:01 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.223.0/10.5.223.12/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:13:01 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.223.12/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.5.223.254, lease-time: 31536000]
. 2018.07.10 15:13:01 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:13:01 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:13:02 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:1df::100a store=active
. 2018.07.10 15:13:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1df::1 validate=no
. 2018.07.10 15:13:03 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1df::/64 -> fde6:7a:7d20:1df::100a metric 0) dev Ethernet 2
. 2018.07.10 15:13:03 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1df::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:13:03 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:13:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:13:08 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:13:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:13:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:13:08 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.223.1
. 2018.07.10 15:13:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:13:08 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.223.1
. 2018.07.10 15:13:08 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1df::1 metric -1) dev Ethernet 2
. 2018.07.10 15:13:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:13:08 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:13:09 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1df::1 metric -1) dev Ethernet 2
. 2018.07.10 15:13:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:13:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:13:09 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1df::1 metric -1) dev Ethernet 2
. 2018.07.10 15:13:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:13:09 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1df::1 metric -1) dev Ethernet 2
. 2018.07.10 15:13:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:13:09 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:13:09 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:13:09 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:13:09 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.5.223.1)
. 2018.07.10 15:13:09 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1df::1)
. 2018.07.10 15:13:09 - Routes, added a new route, 213.152.161.117 for gateway 10.5.223.1
. 2018.07.10 15:13:09 - Routes, added a new route, 2a00:1678:2470:24:159a:2993:1be:4ef for gateway fde6:7a:7d20:1df::1
. 2018.07.10 15:13:09 - Flushing DNS
I 2018.07.10 15:13:13 - Checking route IPv4
I 2018.07.10 15:13:13 - Checking route IPv6
. 2018.07.10 15:13:33 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:13:33 - Checking route (2° try)
. 2018.07.10 15:13:54 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:13:54 - Checking route (3° try)
. 2018.07.10 15:14:16 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 15:14:16 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:14:16 - Disconnecting
. 2018.07.10 15:14:16 - Routes, removed a route previously added, 213.152.161.120 for gateway 192.168.0.1
. 2018.07.10 15:14:16 - Routes, removed a route previously added, 213.152.161.117 for gateway 10.5.223.1
. 2018.07.10 15:14:17 - Routes, removed a route previously added, 2a00:1678:2470:24:159a:2993:1be:4ef for gateway fde6:7a:7d20:1df::1
. 2018.07.10 15:14:17 - SSL > 2018.07.10 15:13:59 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:14:17 - SSL > 2018.07.10 15:13:59 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:14:17 - Sending management termination signal
. 2018.07.10 15:14:17 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:14:17 - OpenVPN > MANAGEMENT: CMD 'e3b67d6ac25eab2df6ce8d6da0366637803e9963342a62a7ccf1fd74eaa82bd7'
. 2018.07.10 15:14:26 - Sending management termination signal
. 2018.07.10 15:14:26 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:14:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:14:26 - SSL > 2018.07.10 15:14:26 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:14:26 - SSL > 2018.07.10 15:14:26 LOG5[0]: Connection reset: 9389 byte(s) sent to TLS, 19263 byte(s) sent to socket
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.5.223.1
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.5.223.1
. 2018.07.10 15:14:26 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:14:26 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:14:26 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:14:26 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:14:26 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:14:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:14:27 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:14:27 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1df::/64)
. 2018.07.10 15:14:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1df::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:14:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1df::100a store=active
. 2018.07.10 15:14:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:14:27 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:14:27 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:14:36 - Sending soft termination signal
. 2018.07.10 15:14:36 - Connection terminated.
. 2018.07.10 15:14:36 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:14:36 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:14:36 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:14:36 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:14:36 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:14:36 - Cancel requested.
! 2018.07.10 15:14:36 - Session terminated.
I 2018.07.10 15:14:46 - Session starting.
I 2018.07.10 15:14:46 - Checking authorization ...
! 2018.07.10 15:14:46 - Connecting to Zaniah (Sweden, Uppsala)
. 2018.07.10 15:14:46 - Routes, added a new route, 62.102.148.197 for gateway 192.168.0.1
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:46 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:46 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:46 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:46 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\79dc286fd0212f1f7b9ce3b0f44cd2d220cae709d2b075107518f7737780d44e.tmp.ssl
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:46 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG5[ui]: Configuration successful
. 2018.07.10 15:14:47 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:14:47 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:14:47 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:14:47 - Connection to OpenVPN Management Interface
. 2018.07.10 15:14:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:14:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:14:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:14:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:14:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:14:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:35332
. 2018.07.10 15:14:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:14:47 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:35332 [nonblock]
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49879
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: s_connect: connecting 62.102.148.197:443
. 2018.07.10 15:14:47 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:35332
. 2018.07.10 15:14:47 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:14:47 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:35332
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG5[0]: s_connect: connected 62.102.148.197:443
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:49880
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: SNI: sending servername: 62.102.148.197
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: Peer certificate not required
. 2018.07.10 15:14:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: Client certificate not requested
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:14:47 - SSL > 2018.07.10 15:14:47 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:14:47 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:35332, sid=6ae32f45 384c1545
. 2018.07.10 15:14:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:14:47 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:14:47 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:14:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:14:47 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:14:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:14:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:14:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:35332
. 2018.07.10 15:14:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:14:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.199.1,dhcp-option DNS6 fde6:7a:7d20:1cc7::1,tun-ipv6,route-gateway 10.32.199.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1cc7::100c/64 fde6:7a:7d20:1cc7::1,ifconfig 10.32.199.14 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:14:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:14:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:14:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:14:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:14:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:14:49 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:14:49 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:14:49 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:14:49 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:14:49 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:14:49 - OpenVPN > open_tun
. 2018.07.10 15:14:49 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:14:49 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:14:49 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.32.199.0/10.32.199.14/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:14:49 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.32.199.14/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.32.199.254, lease-time: 31536000]
. 2018.07.10 15:14:49 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:14:49 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:14:50 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:1cc7::100c store=active
. 2018.07.10 15:14:51 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1cc7::1 validate=no
. 2018.07.10 15:14:51 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1cc7::/64 -> fde6:7a:7d20:1cc7::100c metric 0) dev Ethernet 2
. 2018.07.10 15:14:51 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1cc7::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:14:51 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:14:56 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:14:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:14:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:14:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:14:56 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:14:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:14:56 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:14:56 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:14:56 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:14:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:14:56 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:14:56 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:14:56 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:14:57 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.32.199.1)
. 2018.07.10 15:14:57 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1cc7::1)
. 2018.07.10 15:14:57 - Routes, added a new route, 62.102.148.175 for gateway 10.32.199.1
. 2018.07.10 15:14:57 - Routes, added a new route, 2a00:1520:27:1:cc78:b232:f6cd:88e6 for gateway fde6:7a:7d20:1cc7::1
. 2018.07.10 15:14:57 - Flushing DNS
I 2018.07.10 15:15:00 - Checking route IPv4
I 2018.07.10 15:15:01 - Checking route IPv6
. 2018.07.10 15:15:21 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:15:21 - Checking route (2° try)
. 2018.07.10 15:15:42 - curl: (28) Connection timed out after 20000 milliseconds
. 2018.07.10 15:15:42 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:15:42 - Disconnecting
. 2018.07.10 15:15:42 - Routes, removed a route previously added, 62.102.148.197 for gateway 192.168.0.1
. 2018.07.10 15:15:42 - Routes, removed a route previously added, 62.102.148.175 for gateway 10.32.199.1
. 2018.07.10 15:15:42 - Routes, removed a route previously added, 2a00:1520:27:1:cc78:b232:f6cd:88e6 for gateway fde6:7a:7d20:1cc7::1
. 2018.07.10 15:15:42 - Sending management termination signal
. 2018.07.10 15:15:42 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:15:42 - OpenVPN > MANAGEMENT: CMD '2c770281cc5f0daa933266e20e5f447653d1f82f5da1ce5b5cabedfe7f195389'
. 2018.07.10 15:15:46 - SSL > 2018.07.10 15:15:46 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:15:46 - SSL > 2018.07.10 15:15:46 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:15:52 - Sending management termination signal
. 2018.07.10 15:15:52 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:15:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:15:52 - SSL > 2018.07.10 15:15:52 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:15:52 - SSL > 2018.07.10 15:15:52 LOG5[0]: Connection reset: 7826 byte(s) sent to TLS, 15355 byte(s) sent to socket
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:15:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:15:52 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:15:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:15:52 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:15:52 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:15:52 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:15:52 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:15:52 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1cc7::/64)
. 2018.07.10 15:15:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1cc7::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:15:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1cc7::100c store=active
. 2018.07.10 15:15:53 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:15:53 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:15:53 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:16:02 - Sending soft termination signal
. 2018.07.10 15:16:02 - Connection terminated.
. 2018.07.10 15:16:02 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:16:02 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:16:02 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:16:02 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:16:02 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:16:02 - Cancel requested.
! 2018.07.10 15:16:02 - Session terminated.
! 2018.07.10 15:16:04 - Deactivation of Network Lock
. 2018.07.10 15:19:58 - Updating systems & servers data ...
. 2018.07.10 15:19:58 - Systems & servers data update completed
! 2018.07.10 15:27:24 - Activation of Network Lock - Windows Filtering Platform
I 2018.07.10 15:27:33 - Session starting.
I 2018.07.10 15:27:33 - Checking authorization ...
! 2018.07.10 15:27:34 - Connecting to Zaniah (Sweden, Uppsala)
. 2018.07.10 15:27:34 - Routes, added a new route, 62.102.148.197 for gateway 192.168.0.1
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\bc4c71dd9a7f1f6646427ed82fd28e51b52b53d8d834da2122e2e236eb780c82.tmp.ssl
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[ui]: Configuration successful
. 2018.07.10 15:27:37 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:27:37 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:27:37 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:27:37 - Connection to OpenVPN Management Interface
. 2018.07.10 15:27:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:27:37 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:27:37 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:27:37 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:27:37 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:27:37 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:42753
. 2018.07.10 15:27:37 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:27:37 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:42753 [nonblock]
. 2018.07.10 15:27:37 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:42753
. 2018.07.10 15:27:37 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:27:37 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:42753
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:49974
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG6[0]: s_connect: connecting 62.102.148.197:443
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[0]: s_connect: connected 62.102.148.197:443
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:49975
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG6[0]: SNI: sending servername: 62.102.148.197
. 2018.07.10 15:27:37 - SSL > 2018.07.10 15:27:37 LOG6[0]: Peer certificate not required
. 2018.07.10 15:27:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:27:38 - SSL > 2018.07.10 15:27:37 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:27:38 - SSL > 2018.07.10 15:27:37 LOG6[0]: Client certificate not requested
. 2018.07.10 15:27:38 - SSL > 2018.07.10 15:27:38 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:27:38 - SSL > 2018.07.10 15:27:38 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:27:38 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:42753, sid=2a0f50f5 216b9660
. 2018.07.10 15:27:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:27:38 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:27:38 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:27:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:27:38 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:27:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:27:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:27:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:42753
. 2018.07.10 15:27:39 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:27:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.199.1,dhcp-option DNS6 fde6:7a:7d20:1cc7::1,tun-ipv6,route-gateway 10.32.199.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1cc7::100c/64 fde6:7a:7d20:1cc7::1,ifconfig 10.32.199.14 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:27:39 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:27:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:27:39 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:27:39 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:27:39 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:27:39 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:27:39 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:27:39 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:27:39 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:27:39 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:27:39 - OpenVPN > open_tun
. 2018.07.10 15:27:39 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:27:39 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:27:39 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.32.199.0/10.32.199.14/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:27:39 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.32.199.14/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.32.199.254, lease-time: 31536000]
. 2018.07.10 15:27:39 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:27:39 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:27:40 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:1cc7::100c store=active
. 2018.07.10 15:27:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1cc7::1 validate=no
. 2018.07.10 15:27:42 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1cc7::/64 -> fde6:7a:7d20:1cc7::100c metric 0) dev Ethernet 2
. 2018.07.10 15:27:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1cc7::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:27:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:27:47 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:27:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:27:47 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:27:47 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:27:47 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:27:47 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:27:47 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:27:47 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:27:47 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1cc7::1 metric -1) dev Ethernet 2
. 2018.07.10 15:27:47 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:27:47 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:27:47 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:27:47 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:27:47 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.32.199.1)
. 2018.07.10 15:27:47 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1cc7::1)
. 2018.07.10 15:27:47 - Routes, added a new route, 62.102.148.175 for gateway 10.32.199.1
. 2018.07.10 15:27:48 - Routes, added a new route, 2a00:1520:27:1:cc78:b232:f6cd:88e6 for gateway fde6:7a:7d20:1cc7::1
. 2018.07.10 15:27:48 - Flushing DNS
I 2018.07.10 15:27:51 - Checking route IPv4
I 2018.07.10 15:27:51 - Checking route IPv6
. 2018.07.10 15:28:11 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:28:11 - Checking route (2° try)
. 2018.07.10 15:28:32 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 15:28:32 - Checking route (3° try)
. 2018.07.10 15:28:54 - curl: (28) Connection timed out after 20016 milliseconds
E 2018.07.10 15:28:54 - Checking route IPv6 failed.
. 2018.07.10 15:28:54 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:28:54 - Disconnecting
. 2018.07.10 15:28:54 - Routes, removed a route previously added, 62.102.148.197 for gateway 192.168.0.1
. 2018.07.10 15:28:55 - Routes, removed a route previously added, 62.102.148.175 for gateway 10.32.199.1
. 2018.07.10 15:28:55 - Routes, removed a route previously added, 2a00:1520:27:1:cc78:b232:f6cd:88e6 for gateway fde6:7a:7d20:1cc7::1
. 2018.07.10 15:28:55 - SSL > 2018.07.10 15:28:37 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:28:55 - SSL > 2018.07.10 15:28:37 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:28:55 - Sending management termination signal
. 2018.07.10 15:28:55 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:28:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:28:55 - SSL > 2018.07.10 15:28:55 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:28:55 - SSL > 2018.07.10 15:28:55 LOG5[0]: Connection reset: 8162 byte(s) sent to TLS, 14885 byte(s) sent to socket
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:28:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.32.199.1
. 2018.07.10 15:28:55 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:28:55 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:28:55 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:28:55 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:28:55 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:28:55 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:28:55 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1cc7::/64)
. 2018.07.10 15:28:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1cc7::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:28:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1cc7::100c store=active
. 2018.07.10 15:28:56 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:28:56 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:28:56 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:29:04 - Sending soft termination signal
. 2018.07.10 15:29:04 - Connection terminated.
. 2018.07.10 15:29:04 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:29:04 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:29:04 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:29:04 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:29:04 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:29:07 - Checking authorization ...
! 2018.07.10 15:29:08 - Connecting to Salm (Netherlands, Alblasserdam)
. 2018.07.10 15:29:08 - Routes, added a new route, 213.152.161.23 for gateway 192.168.0.1
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\f7659e52ca9ae5ab95fbdad8ad6274f70de89bbdaa30684e97776316df565039.tmp.ssl
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[ui]: Configuration successful
. 2018.07.10 15:29:08 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:29:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:29:08 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:29:08 - Connection to OpenVPN Management Interface
. 2018.07.10 15:29:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:29:08 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:29:08 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:29:08 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:29:08 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:29:08 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:9732
. 2018.07.10 15:29:08 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:29:08 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:9732 [nonblock]
. 2018.07.10 15:29:08 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:9732
. 2018.07.10 15:29:08 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:29:08 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:9732
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50007
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: s_connect: connecting 213.152.161.23:443
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[0]: s_connect: connected 213.152.161.23:443
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50008
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: SNI: sending servername: 213.152.161.23
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: Peer certificate not required
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:29:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: Client certificate not requested
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:29:08 - SSL > 2018.07.10 15:29:08 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:29:08 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:9732, sid=a5a99112 902ebc5d
. 2018.07.10 15:29:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:29:09 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:29:09 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:29:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:29:09 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:29:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:29:09 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:29:09 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9732
. 2018.07.10 15:29:10 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:29:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.31.1,dhcp-option DNS6 fde6:7a:7d20:191f::1,tun-ipv6,route-gateway 10.29.31.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:191f::1006/64 fde6:7a:7d20:191f::1,ifconfig 10.29.31.8 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:29:10 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:29:10 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:29:10 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:29:10 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:29:10 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:29:10 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:29:10 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:29:10 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:29:10 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:29:10 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:29:10 - OpenVPN > open_tun
. 2018.07.10 15:29:10 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:29:10 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:29:10 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.29.31.0/10.29.31.8/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:29:10 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.29.31.8/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.29.31.254, lease-time: 31536000]
. 2018.07.10 15:29:10 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:29:10 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:29:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:191f::1006 store=active
. 2018.07.10 15:29:12 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:191f::1 validate=no
. 2018.07.10 15:29:12 - OpenVPN > add_route_ipv6(fde6:7a:7d20:191f::/64 -> fde6:7a:7d20:191f::1006 metric 0) dev Ethernet 2
. 2018.07.10 15:29:12 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:191f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:29:12 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:29:18 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:29:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:29:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.29.31.1
. 2018.07.10 15:29:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.29.31.1
. 2018.07.10 15:29:18 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:191f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:29:18 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:29:18 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:191f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:29:18 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:191f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:29:18 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:191f::1 metric -1) dev Ethernet 2
. 2018.07.10 15:29:18 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:29:18 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:29:18 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:29:18 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:29:19 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.29.31.1)
. 2018.07.10 15:29:19 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:191f::1)
. 2018.07.10 15:29:19 - Routes, added a new route, 213.152.161.20 for gateway 10.29.31.1
. 2018.07.10 15:29:19 - Routes, added a new route, 2a00:1678:2470:4a:5908:1fce:a15f:5c5a for gateway fde6:7a:7d20:191f::1
. 2018.07.10 15:29:19 - Flushing DNS
I 2018.07.10 15:29:22 - Checking route IPv4
I 2018.07.10 15:29:22 - Checking route IPv6
. 2018.07.10 15:29:42 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.07.10 15:29:42 - Checking route (2° try)
. 2018.07.10 15:30:04 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 15:30:04 - Checking route (3° try)
. 2018.07.10 15:30:26 - curl: (28) Connection timed out after 20000 milliseconds
. 2018.07.10 15:30:26 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 15:30:26 - Disconnecting
. 2018.07.10 15:30:26 - Routes, removed a route previously added, 213.152.161.23 for gateway 192.168.0.1
. 2018.07.10 15:30:26 - Routes, removed a route previously added, 213.152.161.20 for gateway 10.29.31.1
. 2018.07.10 15:30:26 - Routes, removed a route previously added, 2a00:1678:2470:4a:5908:1fce:a15f:5c5a for gateway fde6:7a:7d20:191f::1
. 2018.07.10 15:30:26 - SSL > 2018.07.10 15:30:08 LOG6[cron]: Executing cron jobs
. 2018.07.10 15:30:26 - SSL > 2018.07.10 15:30:08 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 15:30:26 - Sending management termination signal
. 2018.07.10 15:30:26 - Management - Send 'signal SIGTERM'
. 2018.07.10 15:30:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 15:30:26 - SSL > 2018.07.10 15:30:26 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 15:30:26 - SSL > 2018.07.10 15:30:26 LOG5[0]: Connection reset: 8548 byte(s) sent to TLS, 17392 byte(s) sent to socket
. 2018.07.10 15:30:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:30:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 15:30:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.29.31.1
. 2018.07.10 15:30:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.29.31.1
. 2018.07.10 15:30:26 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 15:30:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:30:26 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:30:26 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 15:30:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:30:26 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 15:30:26 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:30:27 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 15:30:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:30:27 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:30:27 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 15:30:27 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:191f::/64)
. 2018.07.10 15:30:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:191f::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:30:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:191f::1006 store=active
. 2018.07.10 15:30:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.07.10 15:30:27 - OpenVPN > TAP: DHCP address released
. 2018.07.10 15:30:27 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 15:30:36 - Sending soft termination signal
. 2018.07.10 15:30:36 - Connection terminated.
. 2018.07.10 15:30:36 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:30:36 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.07.10 15:30:36 - DNS leak protection with packet filtering disabled.
. 2018.07.10 15:30:36 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 15:30:36 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 15:30:36 - Cancel requested.
! 2018.07.10 15:30:36 - Session terminated.
. 2018.07.10 15:30:55 - Updating systems & servers data ...
. 2018.07.10 15:30:56 - Systems & servers data update completed
I 2018.07.10 15:31:50 - Session starting.
I 2018.07.10 15:31:50 - Checking authorization ...
! 2018.07.10 15:31:50 - Connecting to Adhara (Germany, Frankfurt)
. 2018.07.10 15:31:50 - Routes, added a new route, 185.104.184.46 for gateway 192.168.0.1
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:50 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:50 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:50 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:50 LOG5[ui]: Reading configuration from file C:\Users\gerha\AppData\Local\AirVPN\8bd16233b89464a0f7817a641cda5db00b489b9f4b4321f3990549a61562db50.tmp.ssl
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:50 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG5[ui]: Configuration successful
. 2018.07.10 15:31:51 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 15:31:51 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.07.10 15:31:51 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 15:31:51 - Connection to OpenVPN Management Interface
. 2018.07.10 15:31:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 15:31:51 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:31:51 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:31:51 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2018.07.10 15:31:51 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2018.07.10 15:31:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:53723
. 2018.07.10 15:31:51 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.07.10 15:31:51 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:53723 [nonblock]
. 2018.07.10 15:31:51 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:53723
. 2018.07.10 15:31:51 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 15:31:51 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:53723
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50037
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: s_connect: connecting 185.104.184.46:443
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG5[0]: s_connect: connected 185.104.184.46:443
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG5[0]: Service [openvpn] connected remote server from 192.168.0.101:50038
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: SNI: sending servername: 185.104.184.46
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: Peer certificate not required
. 2018.07.10 15:31:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: Certificate verification disabled
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: Client certificate not requested
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 15:31:51 - SSL > 2018.07.10 15:31:51 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 15:31:51 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:53723, sid=1942084a 835245b8
. 2018.07.10 15:31:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 15:31:51 - OpenVPN > VERIFY KU OK
. 2018.07.10 15:31:51 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 15:31:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 15:31:51 - OpenVPN > VERIFY EKU OK
. 2018.07.10 15:31:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.07.10 15:31:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 15:31:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:53723
. 2018.07.10 15:31:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 15:31:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.191.1,dhcp-option DNS6 fde6:7a:7d20:bf::1,tun-ipv6,route-gateway 10.4.191.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:bf::1001/64 fde6:7a:7d20:bf::1,ifconfig 10.4.191.3 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 15:31:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 15:31:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 15:31:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 15:31:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:31:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 15:31:52 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 15:31:52 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=13 HWADDR=f4:4d:30:61:5b:8c
. 2018.07.10 15:31:52 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 15:31:52 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden.   (code=1168)
. 2018.07.10 15:31:52 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 15:31:52 - OpenVPN > open_tun
. 2018.07.10 15:31:52 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}.tap
. 2018.07.10 15:31:52 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 15:31:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.191.0/10.4.191.3/255.255.255.0 [SUCCEEDED]
. 2018.07.10 15:31:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.191.3/255.255.255.0 on interface {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9} [DHCP-serv: 10.4.191.254, lease-time: 31536000]
. 2018.07.10 15:31:52 - OpenVPN > Successful ARP Flush on interface [29] {58F26AA1-2A71-4E15-BD1E-F0E46B919CF9}
. 2018.07.10 15:31:52 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 15:31:53 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=29 fde6:7a:7d20:bf::1001 store=active
. 2018.07.10 15:31:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:bf::1 validate=no
. 2018.07.10 15:31:55 - OpenVPN > add_route_ipv6(fde6:7a:7d20:bf::/64 -> fde6:7a:7d20:bf::1001 metric 0) dev Ethernet 2
. 2018.07.10 15:31:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:bf::/64 interface=29 fe80::8 store=active
. 2018.07.10 15:31:55 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:32:00 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2018.07.10 15:32:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.07.10 15:32:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.191.1
. 2018.07.10 15:32:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.191.1
. 2018.07.10 15:32:00 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:bf::1 metric -1) dev Ethernet 2
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=29 fe80::8 store=active
. 2018.07.10 15:32:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 15:32:00 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:bf::1 metric -1) dev Ethernet 2
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:32:00 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:bf::1 metric -1) dev Ethernet 2
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=29 fe80::8 store=active
. 2018.07.10 15:32:00 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:bf::1 metric -1) dev Ethernet 2
. 2018.07.10 15:32:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=29 fe80::8 store=active
. 2018.07.10 15:32:01 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 15:32:01 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 15:32:01 - DNS leak protection with packet filtering enabled.
. 2018.07.10 15:32:01 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.4.191.1)
. 2018.07.10 15:32:01 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:bf::1)
. 2018.07.10 15:32:01 - Routes, added a new route, 185.104.184.43 for gateway 10.4.191.1
. 2018.07.10 15:32:01 - Routes, added a new route, 2001:ac8:20:5:e56b:4c39:f245:7761 for gateway fde6:7a:7d20:bf::1
. 2018.07.10 15:32:01 - Flushing DNS
I 2018.07.10 15:32:04 - Checking route IPv4
I 2018.07.10 15:32:05 - Checking route IPv6
. 2018.07.10 15:32:25 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 15:32:25 - Checking route (2° try)
and how should I know now, whether Eddie works properly and runs properly? I've already uninstalled and reinstalled. Registry comments cleaned up what had to do with Eddie and still mistakes.
I dont know if this will help but Ive tried a few different settings etc.....
With my particular system it makes no difference if network lock is activated or not, it still hangs at IPv6 scanning.
If I uncheck settings>advanced>check if tunnel works and have network lock enabled the IPv6 scan is not a problem and the server will connect.
However, after a short time the speed drops to zero and its like a disconnect.
Now if I have both network lock enabled and >check if tunnel works on an IPv4 server only (Celaeno or Nunki) the server will connect
and the connection will be stable for quite a while longer, although eventually it will drop.
My problems began with Eddie 2.13.6 and after updating to latest version they still persist so im guessing its somehow IPv6 related??
I can appreciate the vast variation in systems that users of the Air vpn have so appreciate its not gonna be an instant fix, Ive been a happy customer
for a few years now and never had any real issues so Im confident everything will get sorted out in due course.
Hope this maybe helps anybody else thats having a glitch.
. 2018.07.10 16:24:37 - Eddie version: 2.15.2 / windows_x64, System: Windows, Name: Windows 7 Home Premium, Version: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net: v2.0.50727
. 2018.07.10 16:24:37 - Reading options from C:\Program Files\AirVPN\default.xml
. 2018.07.10 16:24:38 - Command line arguments (0):
. 2018.07.10 16:24:38 - Profile path: C:\Program Files\AirVPN\default.xml
. 2018.07.10 16:24:41 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2018.07.10 16:24:41 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2018.07.10 16:24:41 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2018.07.10 16:24:41 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2018.07.10 16:24:41 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2018.07.10 16:24:41 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
. 2018.07.10 16:24:41 - Updating systems & servers data ...
I 2018.07.10 16:24:42 - Ready
. 2018.07.10 16:24:42 - Systems & servers data update completed
I 2018.07.10 16:24:57 - Session starting.
I 2018.07.10 16:24:57 - Checking authorization ...
! 2018.07.10 16:24:57 - Connecting to Kajam (Netherlands, Alblasserdam)
. 2018.07.10 16:24:58 - Routes, added a new route, 213.152.161.86 for gateway 192.168.1.254
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[ui]: Reading configuration from file C:\Program Files\AirVPN\ee4d0468129994c9c61218eda012abf42b0846a4149a98359875e7c9445210f3.tmp.ssl
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[ui]: Configuration successful
. 2018.07.10 16:24:58 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:24:58 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2018.07.10 16:24:58 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:24:58 - Connection to OpenVPN Management Interface
. 2018.07.10 16:24:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 16:24:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.10 16:24:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.10 16:24:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:41418
. 2018.07.10 16:24:58 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2018.07.10 16:24:58 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:41418 [nonblock]
. 2018.07.10 16:24:58 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:41418
. 2018.07.10 16:24:58 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 16:24:58 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:41418
. 2018.07.10 16:24:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:53188
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG6[0]: s_connect: connecting 213.152.161.86:443
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[0]: s_connect: connected 213.152.161.86:443
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.81:53190
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG6[0]: SNI: sending servername: 213.152.161.86
. 2018.07.10 16:24:58 - SSL > 2018.07.10 16:24:58 LOG6[0]: Peer certificate not required
. 2018.07.10 16:24:59 - SSL > 2018.07.10 16:24:58 LOG6[0]: Certificate verification disabled
. 2018.07.10 16:24:59 - SSL > 2018.07.10 16:24:58 LOG6[0]: Client certificate not requested
. 2018.07.10 16:24:59 - SSL > 2018.07.10 16:24:59 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 16:24:59 - SSL > 2018.07.10 16:24:59 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 16:24:59 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:41418, sid=a75dd0b8 a101565f
. 2018.07.10 16:24:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 16:24:59 - OpenVPN > VERIFY KU OK
. 2018.07.10 16:24:59 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 16:24:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 16:24:59 - OpenVPN > VERIFY EKU OK
. 2018.07.10 16:24:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Kajam, emailAddress=info@airvpn.org
. 2018.07.10 16:24:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 16:24:59 - OpenVPN > [Kajam] Peer Connection Initiated with [AF_INET]127.0.0.1:41418
. 2018.07.10 16:25:00 - OpenVPN > SENT CONTROL [Kajam]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 16:25:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.229.1,dhcp-option DNS6 fde6:7a:7d20:fe5::1,tun-ipv6,route-gateway 10.19.229.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:fe5::1037/64 fde6:7a:7d20:fe5::1,ifconfig 10.19.229.57 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 16:25:00 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 16:25:00 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 16:25:00 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 16:25:00 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:25:00 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:25:00 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 16:25:00 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=11 HWADDR=00:24:8c:3e:fe:f6
. 2018.07.10 16:25:00 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 16:25:00 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2018.07.10 16:25:00 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 16:25:00 - OpenVPN > open_tun
. 2018.07.10 16:25:01 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{854F057F-7592-4A70-90F5-0CB7FD030F92}.tap
. 2018.07.10 16:25:01 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 16:25:01 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.19.229.0/10.19.229.57/255.255.255.0 [sUCCEEDED]
. 2018.07.10 16:25:01 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.19.229.57/255.255.255.0 on interface {854F057F-7592-4A70-90F5-0CB7FD030F92} [DHCP-serv: 10.19.229.254, lease-time: 31536000]
. 2018.07.10 16:25:01 - OpenVPN > Successful ARP Flush on interface [12] {854F057F-7592-4A70-90F5-0CB7FD030F92}
. 2018.07.10 16:25:01 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 16:25:01 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:fe5::1037 store=active
. 2018.07.10 16:25:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:fe5::1 validate=no
. 2018.07.10 16:25:03 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.07.10 16:25:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:fe5::/64 -> fde6:7a:7d20:fe5::1037 metric 0) dev Local Area Connection 2
. 2018.07.10 16:25:04 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:fe5::/64 interface=12 fe80::8 store=active
. 2018.07.10 16:25:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:25:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 16:25:08 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2018.07.10 16:25:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2018.07.10 16:25:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 16:25:08 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.19.229.1
. 2018.07.10 16:25:08 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.19.229.1
. 2018.07.10 16:25:08 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:25:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active
. 2018.07.10 16:25:08 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:25:08 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:25:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active
. 2018.07.10 16:25:08 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:25:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active
. 2018.07.10 16:25:09 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:25:09 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active
. 2018.07.10 16:25:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:25:09 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 16:25:09 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 16:25:09 - DNS leak protection with packet filtering enabled.
. 2018.07.10 16:25:10 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.50.0.1) to 10.19.229.1)
. 2018.07.10 16:25:10 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:fe5::1)
. 2018.07.10 16:25:11 - Routes, added a new route, 213.152.161.85 for gateway 10.19.229.1
. 2018.07.10 16:25:11 - Routes, added a new route, 2a00:1678:2470:17:ce9d:9d0a:18e5:d26e for gateway fde6:7a:7d20:fe5::1
. 2018.07.10 16:25:11 - Flushing DNS
I 2018.07.10 16:25:18 - Checking route IPv4
I 2018.07.10 16:25:18 - Checking route IPv6
. 2018.07.10 16:25:38 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 16:25:38 - Checking route (2° try)
. 2018.07.10 16:25:59 - curl: (28) Connection timed out after 20015 milliseconds
. 2018.07.10 16:25:59 - OpenVPN > Initialization Sequence Completed
! 2018.07.10 16:25:59 - Disconnecting
. 2018.07.10 16:26:00 - Routes, removed a route previously added, 213.152.161.86 for gateway 192.168.1.254
. 2018.07.10 16:26:00 - Routes, removed a route previously added, 213.152.161.85 for gateway 10.19.229.1
. 2018.07.10 16:26:01 - Routes, removed a route previously added, 2a00:1678:2470:17:ce9d:9d0a:18e5:d26e for gateway fde6:7a:7d20:fe5::1
. 2018.07.10 16:26:01 - SSL > 2018.07.10 16:25:58 LOG6[cron]: Executing cron jobs
. 2018.07.10 16:26:01 - SSL > 2018.07.10 16:25:58 LOG6[cron]: Cron jobs completed in 0 seconds
. 2018.07.10 16:26:01 - Sending management termination signal
. 2018.07.10 16:26:01 - Management - Send 'signal SIGTERM'
. 2018.07.10 16:26:01 - OpenVPN > MANAGEMENT: CMD '17fd5b884597cfaab0f8604d1e430f594c834efbd669c3ef28f07762e4e408cf'
. 2018.07.10 16:26:10 - Sending management termination signal
. 2018.07.10 16:26:10 - Management - Send 'signal SIGTERM'
. 2018.07.10 16:26:10 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.07.10 16:26:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2018.07.10 16:26:10 - SSL > 2018.07.10 16:26:10 LOG3[0]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
. 2018.07.10 16:26:10 - SSL > 2018.07.10 16:26:10 LOG5[0]: Connection reset: 36026 byte(s) sent to TLS, 16425 byte(s) sent to socket
. 2018.07.10 16:26:10 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.07.10 16:26:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.19.229.1
. 2018.07.10 16:26:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.19.229.1
. 2018.07.10 16:26:10 - OpenVPN > delete_route_ipv6(::/3)
. 2018.07.10 16:26:10 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=12 fe80::8 store=active
. 2018.07.10 16:26:10 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:26:10 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.07.10 16:26:10 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=12 fe80::8 store=active
. 2018.07.10 16:26:11 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.07.10 16:26:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=12 fe80::8 store=active
. 2018.07.10 16:26:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:26:11 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.07.10 16:26:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=12 fe80::8 store=active
. 2018.07.10 16:26:11 - OpenVPN > Closing TUN/TAP interface
. 2018.07.10 16:26:11 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:fe5::/64)
. 2018.07.10 16:26:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:fe5::/64 interface=12 fe80::8 store=active
. 2018.07.10 16:26:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Local Area Connection 2 fde6:7a:7d20:fe5::1037 store=active
. 2018.07.10 16:26:12 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Local Area Connection 2 all
. 2018.07.10 16:26:12 - OpenVPN > TAP: DHCP address released
. 2018.07.10 16:26:12 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2018.07.10 16:26:20 - Sending soft termination signal
. 2018.07.10 16:26:20 - Connection terminated.
. 2018.07.10 16:26:20 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to 10.50.0.1)
. 2018.07.10 16:26:21 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2018.07.10 16:26:21 - DNS leak protection with packet filtering disabled.
. 2018.07.10 16:26:21 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2018.07.10 16:26:21 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
I 2018.07.10 16:26:21 - Cancel requested.
! 2018.07.10 16:26:21 - Session terminated.
! 2018.07.10 16:27:05 - Activation of Network Lock - Windows Filtering Platform
I 2018.07.10 16:27:08 - Session starting.
I 2018.07.10 16:27:09 - Checking authorization ...
! 2018.07.10 16:27:09 - Connecting to Kajam (Netherlands, Alblasserdam)
. 2018.07.10 16:27:09 - Routes, added a new route, 213.152.161.86 for gateway 192.168.1.254
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[ui]: Reading configuration from file C:\Program Files\AirVPN\da81c2988fbd896eaec6eb14581e16951244fc4c21f791796924ee836925a531.tmp.ssl
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[ui]: UTF-8 byte order mark not detected
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[ui]: Initializing service [openvpn]
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[ui]: Configuration successful
. 2018.07.10 16:27:10 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.07.10 16:27:10 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2018.07.10 16:27:10 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.07.10 16:27:10 - Connection to OpenVPN Management Interface
. 2018.07.10 16:27:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.07.10 16:27:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.10 16:27:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.07.10 16:27:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:61100
. 2018.07.10 16:27:10 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2018.07.10 16:27:10 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:61100 [nonblock]
. 2018.07.10 16:27:10 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:61100
. 2018.07.10 16:27:10 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2018.07.10 16:27:10 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:61100
. 2018.07.10 16:27:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:53217
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: s_connect: connecting 213.152.161.86:443
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[0]: s_connect: connected 213.152.161.86:443
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG5[0]: Service [openvpn] connected remote server from 192.168.1.81:53218
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: SNI: sending servername: 213.152.161.86
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: Peer certificate not required
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: Certificate verification disabled
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: Client certificate not requested
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: TLS connected: new session negotiated
. 2018.07.10 16:27:10 - SSL > 2018.07.10 16:27:10 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2018.07.10 16:27:10 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:61100, sid=aa5bcb9d 9380d57c
. 2018.07.10 16:27:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.07.10 16:27:10 - OpenVPN > VERIFY KU OK
. 2018.07.10 16:27:10 - OpenVPN > Validating certificate extended key usage
. 2018.07.10 16:27:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.07.10 16:27:10 - OpenVPN > VERIFY EKU OK
. 2018.07.10 16:27:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Kajam, emailAddress=info@airvpn.org
. 2018.07.10 16:27:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.07.10 16:27:11 - OpenVPN > [Kajam] Peer Connection Initiated with [AF_INET]127.0.0.1:61100
. 2018.07.10 16:27:12 - OpenVPN > SENT CONTROL [Kajam]: 'PUSH_REQUEST' (status=1)
. 2018.07.10 16:27:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.229.1,dhcp-option DNS6 fde6:7a:7d20:fe5::1,tun-ipv6,route-gateway 10.19.229.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:fe5::1037/64 fde6:7a:7d20:fe5::1,ifconfig 10.19.229.57 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.07.10 16:27:12 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2018.07.10 16:27:12 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.07.10 16:27:12 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.07.10 16:27:12 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:27:12 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.07.10 16:27:12 - OpenVPN > interactive service msg_channel=0
. 2018.07.10 16:27:12 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=11 HWADDR=00:24:8c:3e:fe:f6
. 2018.07.10 16:27:12 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.07.10 16:27:12 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2018.07.10 16:27:12 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.07.10 16:27:12 - OpenVPN > open_tun
. 2018.07.10 16:27:12 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{854F057F-7592-4A70-90F5-0CB7FD030F92}.tap
. 2018.07.10 16:27:12 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.07.10 16:27:12 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.19.229.0/10.19.229.57/255.255.255.0 [sUCCEEDED]
. 2018.07.10 16:27:12 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.19.229.57/255.255.255.0 on interface {854F057F-7592-4A70-90F5-0CB7FD030F92} [DHCP-serv: 10.19.229.254, lease-time: 31536000]
. 2018.07.10 16:27:12 - OpenVPN > Successful ARP Flush on interface [12] {854F057F-7592-4A70-90F5-0CB7FD030F92}
. 2018.07.10 16:27:12 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.07.10 16:27:13 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:fe5::1037 store=active
. 2018.07.10 16:27:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:fe5::1 validate=no
. 2018.07.10 16:27:15 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.07.10 16:27:15 - OpenVPN > add_route_ipv6(fde6:7a:7d20:fe5::/64 -> fde6:7a:7d20:fe5::1037 metric 0) dev Local Area Connection 2
. 2018.07.10 16:27:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:fe5::/64 interface=12 fe80::8 store=active
. 2018.07.10 16:27:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:27:20 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.07.10 16:27:20 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.1.254
. 2018.07.10 16:27:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2018.07.10 16:27:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.07.10 16:27:20 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.19.229.1
. 2018.07.10 16:27:20 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.19.229.1
. 2018.07.10 16:27:20 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:27:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active
. 2018.07.10 16:27:20 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:27:21 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:27:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active
. 2018.07.10 16:27:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.07.10 16:27:21 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:27:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active
. 2018.07.10 16:27:21 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:fe5::1 metric -1) dev Local Area Connection 2
. 2018.07.10 16:27:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active
. 2018.07.10 16:27:22 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2018.07.10 16:27:22 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2018.07.10 16:27:22 - DNS leak protection with packet filtering enabled.
. 2018.07.10 16:27:23 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.50.0.1) to 10.19.229.1)
. 2018.07.10 16:27:23 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:fe5::1)
. 2018.07.10 16:27:24 - Routes, added a new route, 213.152.161.85 for gateway 10.19.229.1
. 2018.07.10 16:27:24 - Routes, added a new route, 2a00:1678:2470:17:ce9d:9d0a:18e5:d26e for gateway fde6:7a:7d20:fe5::1
. 2018.07.10 16:27:24 - Flushing DNS
I 2018.07.10 16:27:31 - Checking DNS
! 2018.07.10 16:27:32 - Connected.
. 2018.07.10 16:27:32 - OpenVPN > Initialization Sequence Completed
. 2018.07.10 16:28:10 - SSL > 2018.07.10 16:28:10 LOG6[cron]: Executing cron jobs
. 2018.07.10 16:28:10 - SSL > 2018.07.10 16:28:10 LOG6[cron]: Cron jobs completed in 0 seconds
UPDATE:
If anyone is having an issue with IPv6 check hanging during scanning try this (Support guys advised solution and it works for me )
In Eddie "Preferences" > "Networking" set:
Layer IPv4: Inside Tunnel
Layer IPv6: Blocked (HERE IS THE DIFFERENCE)
Protocol used for connection: IPv4 only (another difference)
Click "Save" to save the changes and test again.
UPDATE:
I had the problems trying to connect to ipv6 starting from yesterday for some reason and the above post sorted it for me. Thanks!
UPDATE:
eddie V2.13.6
I can get to "Preferences", but the only tab close to "Networking" is "network lock" and there are no options on that tab that are even close to what is described here.
Can anyone spell this out more clearly for the stupid guy
UPDATE:
Not for me. I've been using those settings for a long time now and I'm still experiencing connection problems.
In Preferences:
Layer IPv6: Blocked
Didn't help. It still complained for being unable to find the IPv6 route and kept disconnecting
Helped editing sysctl.conf
root in terminal
nano /etc/sysctl.conf
#and adding lines:
net.ipv4.ip_forward=1
net.ipv6.ip_forward=1
Save
Then reread with
sysctl -p
And finally, it works in Ubuntu
In Android everything worked asap
I had the same problem and i solved it by:
Preferences:
Networking>> Interface used for connection: Then choose your Network Adapter which shows your current LAN IP address .
Then Save and try to connect again.
